Im in the process of installing a reverse and front cam and want to access accessory power and figure one of the easiest spots may be the back of the power socket in the centre console. I've popped the rear of the rear console up but for the life of me cannot disengage the front pawls which engage into the rear of the front section of the console. I don't want to force it. How do the front pawls lock into the front centre console? Do I pull the sides of the rear console out or rearwards or upwards? I had no difficulty with any of the dash panels! Any help would be much appreciated.
https://www.sau.com.au/forums/topic/327429-removing-rear-centre-console/
Well you are a brave man playing around with a car like a R35 but this should help you out i hope.
r35_console_assembly.pdf
Hope that helps ya. :bunny:
Thanks but I've already got the manual. It's just not terribly descriptive about how to "disengage" the front pawls....
Managed to do it. You pull upwards and backwards quite firmly and it comes out. If you pull up you'll break the pawls. If you pull back you prob might not break them but it requires significantly more force. Simple info like this in the manuals would make life a lot simpler!
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
