r3volt21 Posted July 4, 2010 Share Posted July 4, 2010 Hi, I own a mr30 sedan and have my eye on some patrol 2.8 petrol extractors from a local wrecker and was just wondering if some1 could please tell me the amount I need to bring the flange back to make them fit. I also scored a pair of s1 red on red hotplates for it for free from a friend who wrote his off they have a chunk missing right at the top of the left one and i wouldnt worry as its hardly noticable when on the car but they get water behind, I was just wondering if anyone knows what i could repair this with doesnt have to look that great as i want them in more to make sure i like that style before tracking a good cond set down. Thanks in advance, Paul. Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/ Share on other sites More sharing options...
Factory 5 Posted July 4, 2010 Share Posted July 4, 2010 flange wont need modification. the last bend before the pipes go rear-ward will maybe need bending. (just depends, not every set out there is the same. there are a few manufacturers) clear lexan/perspex or whetever the lights are made of is very hard to repair properly. most adhesives and epoxy will make the inside go all foggy and shit. your best bet is to just use the Aus lights, hotplates arent that special (car wont go any faster) Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5327905 Share on other sites More sharing options...
r3volt21 Posted July 4, 2010 Author Share Posted July 4, 2010 thanks for the replay mag86 are thats even easier to just get it bent to fit looked at mine properly i dont have the flange their anymore anyway my engine pipe has just been expanded at the end and welded straight to my 2.5' exhaust, I might just have a play with the lights, i have some plastics that might work. Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5327921 Share on other sites More sharing options...
Ghostrider Posted July 5, 2010 Share Posted July 5, 2010 hotplates arent that special (car wont go any faster) Says the man that just HAD to HAVE them on his own car??????? Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5329962 Share on other sites More sharing options...
Ghostrider Posted July 5, 2010 Share Posted July 5, 2010 If your trying to repair the lights, like just cracks, get some MEK and that will fuse the plastic together. If you cant get that, superglue is your only option and as Mags said, anything you use is going to create a frosting effect anywhere you put it and the end result will be VERY ordinary, but there is light at the end of the tunnel. As you have S1 lights, that's all red, maybe you could consider colour coding the outer red zone and then nobody would be any the wiser and the light area would only be the visible red. Just a thought that might get your problem solved. Cheers, D Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5329978 Share on other sites More sharing options...
r3volt21 Posted July 6, 2010 Author Share Posted July 6, 2010 As you have S1 lights, that's all red, maybe you could consider colour coding the outer red zone and then nobody would be any the wiser and the light area would only be the visible red. Just a thought that might get your problem solved. Cheers, D Thanks Dan didnt think of colour coding the whole light will give it a go lights didnt cost me anything so i have nothing to loose. Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5330795 Share on other sites More sharing options...
Ghostrider Posted July 14, 2010 Share Posted July 14, 2010 Hi, I own a mr30 sedan and have my eye on some patrol 2.8 petrol extractors from a local wrecker and was just wondering if some1 could please tell me the amount I need to bring the flange back to make them fit. I also scored a pair of s1 red on red hotplates for it for free from a friend who wrote his off they have a chunk missing right at the top of the left one and i wouldnt worry as its hardly noticable when on the car but they get water behind, I was just wondering if anyone knows what i could repair this with doesnt have to look that great as i want them in more to make sure i like that style before tracking a good cond set down. Thanks in advance, Paul. Paul, You might be interested in these? The left appears ok with a chip out of the right so you could end up with a good set for a little money. http://cgi.ebay.com.au/DR30-tailights-RARE...=item3caef398c5 Cheers, D Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5347090 Share on other sites More sharing options...
Socrates Posted July 15, 2010 Share Posted July 15, 2010 I've seen those lights in person, i've been to that guys place to get some R31 Ti rims. They looked fine to me, Chip is quite small 2cmish. Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5347925 Share on other sites More sharing options...
jrh001 Posted July 15, 2010 Share Posted July 15, 2010 I've seen those lights in person, i've been to that guys place to get some R31 Ti rims.They looked fine to me, Chip is quite small 2cmish. 2cm sounds like a fair-sized chip. That's big enough to be called a chunk. Right-hand tail light looks a bit odd in the eBay pic, centre line doesn't seem straight. JH Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5348649 Share on other sites More sharing options...
jrh001 Posted July 17, 2010 Share Posted July 17, 2010 Hotplate auction ended with no bids. I sent the seller two questions (1. asking for better pics via email and 2. asking if the wiring looms were included) and got no replies. JH Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5351368 Share on other sites More sharing options...
r3volt21 Posted July 21, 2010 Author Share Posted July 21, 2010 I would have been interested checked the forums to late auction already ended thanks anyway dan. Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5357810 Share on other sites More sharing options...
Ghostrider Posted July 21, 2010 Share Posted July 21, 2010 Try these on Import Monster, but only 8 hours to go and no bids; http://www.importmonster.com.au/view?url=h...&title=DR30 http://www.importmonster.com.au/view?url=h...&title=DR30 or these with 3 days to go and no bids; http://www.importmonster.com.au/view?url=h...&title=DR30 or these with 4 days to go and no bids; http://www.importmonster.com.au/view?url=h...e=M%20DR30%20Dr Cheers, Dennis Link to comment https://www.sau.com.au/forums/topic/327439-r30-extractors-and-hotplate-q/#findComment-5358136 Share on other sites More sharing options...
