Turning Hr31 Into Awd
Tried to find anything on the forum in regards to fitting the front subframe from a R32GTR into a HR31 to convert to AWD once i fit an RB26DETT in it. Anyway know of any other forum questions like this? Does anyone know the dimensions between the chassis rails of the GTR in the engine bay?
I have never heard of this being done, doesn't mean it hasn't been thought about or done before.
Anything is possible, but it will take time and patients. Helps if you can fabricate things yourself.
Not an HR31 but this guy has the full GTR running gear in his S14: Link
Good luck with it and make sure that you create a build thread if you go ahead.
If they can do it to a VL (like 10 years ago), then you can do it to your 31.. as noted above, hope you have a deep wallet and LOTS of time/patience :ninja:
Someone did it to an oldschool RWD celica, basically had to cut and shut half the car to do it though.
No offence but this is a pretty retarded idea, you will spend a ridiculous amount of money to end up with an unregistrable hack of a car that will most likely have completely messed up suspension geometry and handle like ass. Why do you want to do it?
To be honest if you have to ask people on a forum how to go about it, you probably aren't the kind of person to be even attempting it.
the man asked a question on any other places to look to get ideas on the modification i dont see where he asked for ur opinions on the matter.
the only thing i can say is its alot of work but its doable start looking for the people who have done it to the vl's and id say ur somewhat on your way to figuring out whether its viable/in ur price range, or not
but as everyone said BUILD THREAD plz
Of course it is doable - however the time, cost and effort need to be really addressed as there is extensive modification just to get a GTR REAR end into a HR31...
Let alone the front end as the subframe sits lower and so on as my RB26 sits signifigantly lower to the ground than in a GTR.
I'd also question if the transmission tunnel can even allow for the driveshaft as my initial inclination would be a no, meaning floor cutting as well.
A good question here is this:
Will the added weight & customisation of the 4WD really make a HR31 that much faster than if you spend even just half that money on the HR31 IRS and reconfiguring it with weight advantages already posed.
Nismoid you think too much... weight, faster, money! You are jealous because it will be cooler than yours ;)
Just do it. Buy an R32 GTR (complete) take out the running gear and sell the shell to me for real cheap. Then a**hole everything into an empty HR31 shell.
Easy right?
Of course i think too much. I get paid to do so afterall.
After putting together a motor for 5 figures, then all the rest, you really have to "draw a line" at some point on a shell that is essentially worth nothing.
Going 4WD would be "that point" given the price of R32 GTR's these days :)
That's not to say I've not thought about 4WD myself, looked into that as well a few years back :)
 Share
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
