Silver 32 Gtst
Been on here a while but has taken me a while to post up my car. Bought from forum member in January after selling my MX5.
It has full exhaust, stock turbo, Power FC, FMIC, boost controller, 1.5 way low ratio (not sure what ratio but it is short!) LSD, upgraded radiator, BC Gold coilovers....178rwkw at 14psi
More pics and mods to come....
Interior mods, Nardi wheel and nismo gear knob.
I am looking for another quality knob as I don't like most of the nismo ones. This one is a little square at the top compared to what I want. Any ideas? It must be heavy (see next pic!) and a direct screw in to the factory gear stick thread... I hate the ones with rubber grommets which don't feel solid.
Nismo short throw unit
Wheels are Kosei Direzza RCS 17x8 +33 front and rears 17x9 +33. Made in Japan and according to my research they are forged???? (Can anyone confirm? They seem light but not convinced they are forged. They look similar to WOrk KAI CR but not as nice :yes: Don't like how I have to use hex lugs rather than my Rays nuts which weight F*&Kall and look better). I am trying to find some extended blue lugs which will rice them up a bit.
I need to roll the rear guards (front already done) before I can fit the rears. I may also add my 5mm spacers and/or go to a 245/40 tyre (currently 235s). Front is very close to flush as is...
Funny thing is the Kosei's look smaller than the GTT rims. I think it is the extra lip on the GTT rims and the fact they are black.
Almost there with some power mods.
Z32 AFM
GTR fuel pump
GCG RB25 Steel wheel BB Turbo. Gave up on the HKS 2530 as most of them were too old and expensive for a s/h turbo. Got this cheapish with a good history so will see how it goes. Will be a bit laggy but good for track work. Tossing up whether to get injectors or just install it all and tune around the fuel supply. If the tuner thinks it will be 100% safe I will probably just go for it. Is 220kw asking too much?
and cheapie but strong (as in it actually seems to work) strut brace. Please excuse the sad engine bay:(
Nelson did his stuff on the rear guards this morning. Easy to trust him to do a great job. @$65 per corner money well spent.
Mixed wheel combo gone. Rears are slightly stretched so the profile is not quite as tall so gap is bigger:neutral:
But no more chicken legs from behind!
Before
After
Now off to Tempe to get the tyres swapped over as the ones that came with the wheels are almost shredded.
Thanks Tim.
A bit scary posting a build thread when there are so many higher quality, big buck and skillfully developed cars on here. Looks like there is a place for everyone though, even my little GT
lookin good mate. got contact details for nelson? did he say how far he can roll the guards?
He can roll them completely flat and flare as well if necessary. He is the only guy I know who does most of the car dealer work as well as some Porsche and Ferrari work. Nice bloke. Give him a call. Ph 0432 109 331.
Edited by spranga
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
