What kind of problems would i have with regency if i this http://www.skylinesaustralia.com/forums/R3...56#entry5337356
Performance Features....
- Splitfire coil packs - no problems
- 550cc injectors - out for Regency
- 550 hp ATR-43 turbo - out for Regency
- Z32 Air flow meter - off
- Stealth return flow front mount intercooler - fine as long as no chassis is modified, holes are cut properly and mounting is secure
- Greddy turbo timer - take it out for regency
- Nistune ECU - not sure, but probably remove
- Trust turbo back exhaust - as long as its quiet enough
- Extreme heavy duty street button clutch - fine
- Walbro fuel pump - fine
- Tuned by Dr Drift on a safe tune of 236rwkw at only 15psi, easy to drive (I drive it everyday) and decent fuel economy. Will easily get 450kms to 50 litres with highway driving.
The wheels are 18's, with Kumho ku36's on the rear. - should be ok by the looks.
  • Replies 89
well unless you know how to take the turbo and injectors out, i wouldnt do it yourself. But alot of those mods aren't standout type mods, so you should be fine for an ID inspection.
I'd leave the turbo on if you take it through regency as with the Z32 AFM - Only if you get pulled up on it. I'd leave the nistune ecu, absolutely no way they'll know, even if they pull the ECU apart I put my balls on the line they won't know what they're looking for. Injectors can be a kent to do, turbo timer could take 2 minutes.
The 34 looks stunning mate btw!
Yeah those look pretty bad - though I've seen worse (check out some of the r33s on the road!)
Anyways, you can polish them up with various products - I've tried just about everything from plastx to toothpaste to brasso. I recently used one called 'glassylite': http://www.glassylite.net.au/ which was supposed to have a UV sealant and stop the clouding happening again. Guess we'll see if it works!
Got other pics of the car?
Another prospect car.
car 6 link
My only concerns are:
1. its nearly due to 100k service
2. selling it on behalf of his friend who is over seas
3. not sure exactly what to look for when inspecting it (anyone come along with me help me check it out)
i've seen this car parked on the side of the road in Modbury with the for sale signs up in the window. It looked VERY clean on the outside
The guy i rang "Jeff" was selling it on behalf of his friend who was over seas, i dont know how that would work (signing it over) without him being there :S
But im sick of seeing silver skylines, gotta go black or red :P
Edited by Blazk
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
