hey ppl having some issues withe my wipers they randomly stop in the wring spot when i turn them off
somtimes at the top somtimes in the middle of the windscreen some times in the right spot.... anywhere they want to.
they just dont wanna return to the right spot at the bottom
well somtimes they do but not all the time
this is an r33 series 1 gtst.
does anyone have any ideas on what would cause this and how i can fix it...
cheers matt
https://www.sau.com.au/forums/topic/327493-windscreen-wipers-help-me-please/
wipers usually need a continuous power supply to let motor continue when switch is turned off and get it back to rest. if wipers stop soon as you turn off the switch then this is likely at fault
cheers but this is not the issue i should have been a bit clearer
this is when i turn the wipers off and the car is still running
believe it to be the wiper controll box
that is at fault.
this is the little brown box in the top right hand corner of the engine bay abut the sice of a gargae remote control
cheers Matt
yeah mate what i meant was if you turn the switch off half way through its cycle and it doesnt continue to the bottom. but if i understand you now you mean when the switch is left on and the motor doesnt finish its cycle? could be the brown box.lots bigger than my garage remote haha. just need to borrow someones now. goodluck
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
