Coughing?
Guest EVL-R33
ey, just finding a bit of a problem not sure what it is exaclty..
its pretty hard to explain and maybe im just getting used to my cars power,
but it seems not to be going as good as it was b4 not pulling as hard and at the higher rpm where more boost kicks in due to the solidnoid my car starts to like cough (hard to explain) it just cuts on and off but not all the time, some of my friends think its the Cold weather as it happens more in the early morning when ice is falling, another reason could be is i have a lil tiny crack in my ciooler piping where the clamp sits?
can any1 help?:confused:
https://www.sau.com.au/forums/topic/3275-coughing/
The little tiny crack could do it - could open up under boost, releasing some of the already metered air.
Also, might be detonation with the ECU retarding the spark (unlikely).
I'd get the crack fixed.
https://www.sau.com.au/forums/topic/3275-coughing/#findComment-55485
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
