I'm just going to have a stab in the dark and say it moves the focal plane forward or backwards. Either one, once you use it, you'll know how to use it.
It came out on the 1D3's, 1Ds3's, 50D, 7D, 5DmkII and the 1DIV.
So for Nikon i'm guessing its from D90 upwards? Or maybe D300.
Either way Barra, those photos are way too soft, i would look at exchaning it for another copy or just try out all the lenses they have until you are happy (would be much easier if you bought it from a camera shop).
Mat - Cactus's have lasted me a year. Hopefully your "iSHOOT" will last a while! Only misfire every now and then. Dropped them in saltwater and they still work. Until i have spare cash, they will last me. Then i'll upgrade to cybersyncs :nyaanyaa:
Nice shots GoldZilla!
  • Replies 175
Yeah I always thought it was was something only the Nikon full frames had (ie D700, D3, etc)
Wonder if the D300 has it... (I would be very surprised if the D90 has it)
Anyway doesn't matter - you're right - that def doesn't look right
Kory is right about it being soft at 1.4 but that is SO soft i suspect what is happening is that it is focussed either in front or behind the piece of paper and not on the piece of paper itself
so to see if this is the case you need to take a picture of it at 45 degrees..
barraspalding you said you dont have a printer
try this instead
get a ruler (or a brick wall)
pick a specific point on the ruler (or brick wall)
and focus on that point
and take a photo (using tripod) with the lens wide open
and then see if the bit in focus is where you focussed.
To add onto Zennons post.
Make sure your shutter speed is above 1/focal length. To be "doubly" sure, increase it x2. So if your metering it and it suggest the following settings:
1/100th shutter speed
1.4 aperture
ISO 100
Increase this to 1/200th and bump the ISO up to accomodate for a higher shutter speed and make sure your exposure is not underexposed so it is easier to tell the results.
Use a tripod as stated by Zennon at a 45 degree angle, with the ruler in the middle of the frame. Do not shoot from a long way away, try it about 3 feet-4 feet away i think.
In short, this will rule out camera shake EVEN THOUGH it is on a tripod.
You need to eliminate all the errors and make sure its not a user error.
Also, use the Centre focal point and not "Auto" for the most accurate focus as its the largest AF point.
Although this is Nikon and i'm unfamiliar with Nikon, but i believe the lower end cameras (d40/d60) only has 3 focus points?????
As you have stated you don't have a printer, i highly recommend using a 30cm ruler (preferably wood) and focus at around 15cm.
Correct me if i'm wrong about Nikons focal points.
Post up the test images!
So would I have been better off going after a nikon lens? Nikkor 50mm 1.4 af-s.
Or am I doomed to crappy results with large aperture lenses until I upgrade to a half decent camera that can be 'tuned'?
I Think all Lens brands have their faults. Sigma is known in the US to have weak QC.
Unsure how it is in AUS or where we get our stock from, but Nikon would have tighter QC policies and standards within how much a lens can be within tolerances than Sigma.
I suggest sending this back and getting another one. If thats not good enough, then send it back for a refund say your not happy and who knows they might calibrate it for you for your camera. If not, buy a Nikon one if your not happy with it.
Microadjust helps this a lot, but sometimes lenses are just so far out, you can't do it without sending it back.
When you focus with a single point, is the focus in that area, or is it in front or behind?
Try the ruler test then we can determine what is wrong.
I'll take some shots tonight. Currently waiting to hear back from the camerasdirect bloke.
Curious... When u micro adjust the af, does that alter the af for the camera regardless of what lens u bolt on, or just that particular lens?
Cameras direct are pretty good. They have fast turn around and great customer service. Call them up if you dont here back, they have people on phones all the time who know what they are talking about.
You can do both. Either:
Microadjust for A lens.
Microadjust for EVERY lens.
The camera remembers which lens is "bolted" on and what settings you have chosen :)
I got a call back... He's of the opinion that it's ok, and that I shouldn't use or expect good results when using it at it's 'extremes'... I advised him I would conduct the 45degree angle test chart tonight and advise tomorrow.
He was happy to have the lens returned to perform some tests himself also.
Thats good news. The "test chart" he gave you will give seriously inaccurate results.
I would suggest sending it back to them and letting them test it out/give you another copy PENDING your 45 degree test chart samples you post up.
i used http://focustestchart.com as you suggested.
So the results... and really I don't know if its good or not. From what I read in that http://focustestchart.com speel - its common/ok for it to be focused behind slightly... this seems more forward.
F1.4
F2.8
To my eyes, that is backfocusing slightly. Highly impressed actually. I thought it would be much worse from the original photos you posted earlier.
Not writing you off or bashing or anything. Shooting at wide apertures is hard to master! But once you've mastered it. ENJOY!!!!
I would be happy with that. Seeing as you can't microadjust, it seems perfectly fine too me.
Slightly backfocusing, add +1 to about +4 and it would be perfect. Extremely sharp too if this is straight out of the camera.
Great job on the focusing tests! Now get out there and start shooting more :O:D
Yeah I thought it would be worse too... Now I need to invent a new excuse cuz I'm not willing to blame myself without a fight :Op
I'll stick to 2.8 n step up as I get more comfortable
Cheers for all the help & comments... Much appreciated
I don't think manual focus would be an issue IF my camera had the focus thing... I recall an old film camera I used in high school had two half circles that would slide left or right on each other.... They'd create a perfect circle when ur focus was spot on. Do any cameras do that anymore??? Cuz I'm unsure how manual focus could be used effectively without something to indicate.
Hopefully that made sense
What camera are you using? Focusing is on the lens. There's usually a switch to unlock it so you can move it yourself. Any camera should let you manual focus. Some cheaper ones won't auto focus, but that's not the issue.
There might be a switch on the cam body to let you use manual mode too.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
