Chasers Or Status (for Tuning )
maddowse
 Share
and if we're talking specifics, i don't believe Rob tunes Nistune - but if you had a Wolf ecu, Rob would have to be right up there considering how well he knows the product
  • Replies 129
100% agree, if your decision is ecu based then I can see you point. If not not just Rob both there are plenty of very decent Mechanics/tuners who would do a great job.
Hey Aaron it's DMD not DND just to clear it up. No probs with any of them shops it's just down to how much you want to spend and where you want to take it.
Posting from my phone FTW! Stupid auto text.
i do all the mechanical work on my car my self, so Trents system works perfectly for me!
just remember as he does no mechanical work, only tuning... he can only work with what you give him, some people have been sent away, trent is very good... but no one can polish a turd!
Yes we did do Jesse's car and we also did his good mates 626 crazy piece of work at 360fwkw very scary and funncar with all that power at the front. Lane skipping fun.
We also use all quality Martini products thanks Jesse
i'm just gonna jump on the bandwagon and say status. trent is a top bloke
never dealt with the others though, i'm sure they are much the same...
Status.
Of small amount of tuners I have dealt with Trent & Cat have by far been the best to deal with.
Trent will take the time to get things right and if there is ever any issues he is always happy to work with you to get the tune you are after.
Every dollar I have spent with Status was/and is worth it.
The one that went bang at calder?
That would not be Trent's fault, hence why I asked who built the motor. Made a big mess, not good when a motor disintergrates during a pass...
Bit of a shame as many were interested in seeing what it would clock up on the boards.
i wld strongly recommend chasers.. paul has given me an awsome tune with 365AWKW + massive response.. paul tune's the car for application, and what is power without response?
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
