The Bayside blue R34 GTR has SSR Professor SP1's. Notice how the stud pattern blends into the spoke design. Same wheels as mine.
SP1's have a flatter spoke design whereas the Meisters spokes curve more.
The 3 Piece Work Meister will have the stud patterns separate from the spokes making the rim "look" smaller.
^ thanks for confirming!
whilst i am here, i may as well post another pic of my gtr hehe...here is a pic with the funky rear tail lights illuminated :) now with better quality image!
Edited by Marko R1
Fitment of filling out the guards look good.
What wheel size, offset and type of wheels you running?
wheels are 19x9.5 +30, axis wheels which have a lot of dish & surprising as light as japanese wheels when i looked the at wheel weight chart
Yeah right.
9.5 wide wheels sit so nice on a R32 GTR, fills it out nicely.
Welldone!
P.S. Since when do you venture out of the "Aussie Delivered R32 GTR's" thread? :laugh:
Yeah right.
Welldone!
haha this is true - most of my time these days is in the ADM thread - when i had my black gtr though, i lived & breathed in the forced induction "rb30 thread" - things change i guess :)
Haha!
That's cool, all good man!
above r34 is a ztune not s tune, the rims are a custom offset lm gt4 made only for the r34 ztune but cant remember what the offset is exactly
i think mark was referring to the R32 S-tune in the pic he posted.
i find myself mistaking people's attachments for signatures in the new layout
Edited by alex182
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
