Item Summary: r33 skyline turbo nissan skyline r33 gtst
Condition: Used
Reason for Selling: want a change
Asking Price: 9500
Delivery Methods: PickUp
Contact Info: 0405591342
Extra Information:
hay guys up for sale it my nissan skyline, im selling due to wanting change and wanting to move. there for im wanting cash but will swap and wanting cash my way, depending on the offer of course. Skyline is pritty clean body apart from a small dent at rear which isnt really noticed. all oiles have been changed 200km ago. gear box has new hd clutch, the 5th sincro in the gear box is on its way out, i just double clutch 5th and have no problems. i put new spark plugs in last week. car is running round 200kw, car just needs new coil pack, new from super cheap i was quoted round $200, on boost there like $100.
car also comes with NSW rego till FEB 2010. with number plates WPN33R.
Nissan skyline 1996 s2
car located near ipswich
134km
manual
hd clutch 3000km old
front mount
adjustable coilovers height and soft or hard contact
slotted front rotors
slotted rear rotors will come in boot, machined just need installing
LSD
pod
gizzmo boost controller set on 10psi
3inch exhaust from turbo back in to a cannon.
after market rear and front speakers
sony head unit
blue and black hand brake and gear stick boots
tint
https://www.sau.com.au/forums/topic/327593-r33-skyline-turbo/
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
