Hi guys,
I've neally finished parting the car and have a few items left which i need.
One being the rear 5 stud hubs wont come off
is there a technique or process in which people undertake to remove these?
also what process is to be taken to remove the wiring loom? how hard is it?
cheers
https://www.sau.com.au/forums/topic/327604-rear-hubs-and-wiring-loom/
Hi guys,
cheers
+1
Was going to look this up for you ... but spent all day yesterday moving bricks :) ... and today fixing IT problems. :down:
Whats the trick to removing rear hubs guys. Got a link? Like I said, been busy ... even too busy for the search function :P
+1
nah ruby thats fine
you have helped me out heaps and if it wasn't for you i wouldn't even be up to the bit i am up to now
Simon Michelmore knows the trick
SimonA31 is username
cheers steve i will sus out what simon has to say
also at the moment im running out of time to transfer my brakes to turbo one so i was thinking should i get the conversion done and the convert it to them after a few days? im just going to be chucking the non-turbo brakes anyway.
Anyone by any chance have any stock turbo 33 exhausts?
i cant find SimonA31 on this site :banana:
Ive tried every search for member sbut cant seem to find his account.
I need to talk to him before tomorrow because a persons coming to pick up the wreck at 1pm and i need to get them off by then
can someone help me out
is it hard to take the wiring loom out?
wow im popular haha
theres 4 bolts behind the hub you have to undo.. once the driveshaft is out and all the brake and other crap is off and those bolts are out then the hub will seperate from the knuckle.. some CRC/WD40 and a large soft touch hammer will help in a big way since its most likely a little rusted in there and its a mega tight fit.
have fun
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
