I have for sale a rb20det turbo high flowed with garrett internals.
GT30 compressor wheel and larger exhaust wheel.
.58 exhaust housing.
Made full boost on rb20 same as a stock turbo. and makes good power up top.
just been rebuilt so is in brand new condition, new seals, bearings and balanced.
direct bolt on for rb20. would fit rb25 but would be better suited for r32.
$650 ono
Geelong pickup.
https://www.sau.com.au/forums/topic/327642-rb20-hi-flow-turbo-garrett/
Just wondering if the turbo has had the wastegate hole ported and a larger flap fitted?
I have a stock rb20 turbo so i will compare the sizes when i get it back from the turbo shop after rebuild.
pretty sure it is though.
made just under 200kw.
You say it made just under 200kws atw, was this on a stock engine?
with supporting mods.
-FMIC
-Fuel pump
-Exhaust.
thats about it. Everything else can be left stock.
Unless you want to run Hi boost, As in 18ish psi. May need injectors and z32 AFM
thanks
Ok, id be keen but its just too pricey when i can pick up a rb25 turbo for $200 that pretty much does the same thing, ill never need anything over 14 psi as my cars street driven thats all
Yes you can pick up a Rb25 turbo for $200
and it may last 5 years, may last 5 days. This turbo has just been rebuilt with receipt, So comes with 12mth warranty.
Also your rb25 turbo will be 500prm laggier than this. and this will be able to cope with much more than 14psi, And I'm sure one day you will want to run more than 14psi in the hunt for more power. especially in an rb20.
I understand if its out of your price range, But these hi-flow's are quite rare. And to high flow a turbo will cost you at least $1000.
therefor i see my price as reasonable.
thanks for the interest buddy. happy hunting =)
Luke
  • 1 month later...
hey u said this would be better suited to a 32 why is that, i thought the 32 and 33 turbo was the same plus its been highflowed so it would bolt staight on .. very keen depending on answer
sounds like a good turbo, at a good price too
gl with sale buddy
this turbo can be boosted higher than stock rb25 turbos since it's got steel internals
the stock rb25 turbo for $200 from me is no longer available so this is a good option
anyone interested in a high flow for their rb25 can buy this turbo and my spare high flowed exhaust housing + intake housing for cheap, swap the exhaust housings over and there you have a very capable turbo that can put out 250rwkw
Edited by chiksluvit
gl with sale buddy
Tempting, guys just and update, I decided to use this turbo on my 20, Going great, How much for your rear housing?I could always use more power :D
that will be the limiting factor on this turbo, As i explained to you in my message havoc, Would choke up top, And power would taper off, Also i think you would have boost control problems.
thanks guys =)
the rear + centre + compressor housings + actuator the whole lot for $60, check my signature for link to my sale page for photos...
only the rear housing is high flowed though, done by GCG, they also use garrett parts when they high flow turbos, so it would've been done to garrett specs
so with your price of $575+$60= a bloody good buy for a highflow turbo with garrett internals that will make just as much power as an R33 highflow, if you're still selling it though
  • 4 weeks later...
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
    • Yes, a plan for non-action is always my first sort of plan! I'm happy to see what falls out of invision's update. I had been having some thoughts on what to do with this the other day and they all seem to have fled my memory, after various solar panel induced traumas, squeaking suspension sphericals, etc etc, over the last little bit. I'll try and recall what I had in mind and make sure that I put it into print in some form before the Alzheimer's strikes again.
    • The ability to have both a 5500 stall for launching, and a regular lockup for every other scenario is pretty sweet. Does it actually work well like that though in the real world? Would it hold up to track use and otherwise you'd never know you had a stall converter in it? If so, that's awesome
    • The thing is, once the content has been tagged we can chop and change the end result as much as we want. Its identifying the content in the first place that needs to be done regardless of the final outcome.
    • Sorry @GTSBoy I thought I'd replied here. There's a new BIG version of invision coming out soon, it might be worth waiting until that happens as it contains a lot of improved functionality for tags. My suggestion would be to add a top level page (not thread) with some info on it and then link to sub pages for various topics. We could even just start really simple with 2 or 3 pages underneath it. Those pages could just have a view (like a pre configured search result) of the tags we choose to put on it. We could have some background or an intro on each of these pages. My only issue is that while admins and mods can update the existing content to contain the tags we want, new posts can have whatever tags the author wants. That said, the reason our tags are so messy is because of that, so maybe we restrict tagging to admins/mods in edits.
