Torques Posted July 5, 2010 Share Posted July 5, 2010 (edited) Hi there, I was wondering how much boost the R33S2 turbo can actually deliver if being maxed out? As an experiment I set my boost controller to 1.2 bar, but the boost would never go over .9 - 1 bar. Could it be that the turbine has reached it's mechanical capacity at this level and is actually maxing out? And yes ... I know the turbine is not going to last long with this kind of boost. (it was just a test) Cheers, Andrew Edited July 5, 2010 by Torques Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/ Share on other sites More sharing options...
Pal Posted July 5, 2010 Share Posted July 5, 2010 wont go much over 14 psi / 1 bar. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5329898 Share on other sites More sharing options...
paulos Posted July 5, 2010 Share Posted July 5, 2010 so my r33 series 2 with gready profec spec 2 b with fmic, cat back 3inch can handle 14psi?? what about series 1's Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5329911 Share on other sites More sharing options...
R31Nismoid Posted July 5, 2010 Share Posted July 5, 2010 Anymore than 12psi is well known to do major damage to the turbo. So why try? Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5329913 Share on other sites More sharing options...
JonnoHR31 Posted July 5, 2010 Share Posted July 5, 2010 but to answer your question, they can go a lot more than 1 bar. personally seen around 20psi from a 25 turbo. definately cant reccomend it tho Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5329927 Share on other sites More sharing options...
The Dan Posted July 5, 2010 Share Posted July 5, 2010 Shut the gate completely and watch them go over 40psi Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330129 Share on other sites More sharing options...
SargeRX8 Posted July 5, 2010 Share Posted July 5, 2010 Shut the gate completely and watch them go over 40psi exactly this. As long as nothing is limiting the turbo, it will boost til it blows. What the max is and what the same threshold is are two very different figures. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330169 Share on other sites More sharing options...
Rolls Posted July 5, 2010 Share Posted July 5, 2010 What is the point of failure when overspeeding a stock turbo? Is it the bearings? Or do the impellers become unbalanced and just eat housing and explode? Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330221 Share on other sites More sharing options...
Torques Posted July 5, 2010 Author Share Posted July 5, 2010 (edited) Hi guys, Thanks for all the answers ... I was thinking that the turbo was maxing out since I could not get the boost over 14PSI / 1 BAR (around 7+ on the internal boost meter) Background: I am running this turbo on 13PSI (in High Mode of my boost controller) Yesterday I was at this event here in England where you can do the quarter mile. Some pictures if you like -> Santa Pod Just for the fun of it I tried setting the boost to 1.2BAR, but the boost would never go any higher than roughly 13-14PSI, no matter what. My conclusion was that the turbo was maxing out. Very strange .. Edited July 5, 2010 by Torques Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330260 Share on other sites More sharing options...
Rolls Posted July 5, 2010 Share Posted July 5, 2010 Sounds like the boost controller is faulty. Get a cheapo ball bearing bleed valve, they always work. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330265 Share on other sites More sharing options...
bubba Posted July 6, 2010 Share Posted July 6, 2010 so my r33 series 2 with gready profec spec 2 b with fmic, cat back 3inch can handle 14psi??what about series 1's series 1 33 turbos can handle 14-15psi aslong as you have a nice free flowing exhaust, any restrictions (blocked cat, stock dump/front etc) will heat it up too much and destroy the exhaust wheel. series 2 33 turbos (with the nylon compressor wheel) are notorious for the compressor wheel delaminating much over 12psi, hence I prefer the steel compressor wheeled s1 turbos. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330497 Share on other sites More sharing options...
SlowSkyline Posted July 6, 2010 Share Posted July 6, 2010 The nylon compressor wheel isnt the problem, its the exhaust ceramic wheel, which are the same on S1 & 2 turbos. They usually blow over prolonged use over 12psi. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330626 Share on other sites More sharing options...
paulr33 Posted July 6, 2010 Share Posted July 6, 2010 i think your question is two I was wondering how much boost the R33S2 turbo can actually deliver? I was wondering how much boost the R33S2 turbo can actually deliver efficiently? i suspect they are two different answers as well what good is 37 PSI at the compressor outlet if its inefficient and the intake temp is well past 80deg? efficiency of the std GTST turbos is something that is debated to death over and over some people say 14psi is the limit, some say 12psi and so on its upto you if you think the risk is worth the gain ive had mine on 0.85kgcm2 for about 6 years now and still std unit and 227,000 i wouldnt dare run it at 14psi, i dont think it would be efficienct, and i thinik it would blow the exhaust wheel and risk the motor Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330755 Share on other sites More sharing options...
STATUS Posted July 6, 2010 Share Posted July 6, 2010 What is the point of failure when overspeeding a stock turbo? Is it the bearings? Or do the impellers become unbalanced and just eat housing and explode? the rear turbine separates from the shaft. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330909 Share on other sites More sharing options...
The Dan Posted July 6, 2010 Share Posted July 6, 2010 +1 they are glued on. So the heat generated and the turbine speed cause them to spin right off Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5330913 Share on other sites More sharing options...
bubba Posted July 6, 2010 Share Posted July 6, 2010 The nylon compressor wheel isnt the problem, its the exhaust ceramic wheel, which are the same on S1 & 2 turbos. They usually blow over prolonged use over 12psi. Tell that to the people that have had their nylon compressor wheels delaminate. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5331060 Share on other sites More sharing options...
The Dan Posted July 6, 2010 Share Posted July 6, 2010 Tell that to the people that have had their nylon compressor wheels delaminate. Have you got their contact details? Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5331103 Share on other sites More sharing options...
mad082 Posted July 6, 2010 Share Posted July 6, 2010 Tell that to the people that have had their nylon compressor wheels delaminate. i was running my s2 turbo at 14/15psi and had no issues. as people said, it's the exhaust wheel that packs up it's bat and ball and goes home (which evidently is the cat converter) that causes 99.9% of actual failures on the rb turbos (not counting oil seal leaking as a failure) (whether it be rb20, 25 - r33 s1, s2 or r34, and even the gtr's of each model). this the results in the nylon compressor wheel doing it's impression of a watermelon hitting the ground after being dropped from the top of the empire state building, while the steel wheel just does an impression of an old fighter plane prop that thinks it's a drill bit. Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5331323 Share on other sites More sharing options...
mad082 Posted July 6, 2010 Share Posted July 6, 2010 oh and to answer the original question, the turbo should boost higher than what you are trying to boost it to. the issue you are having could be caused by a few things. 1: faulty boost controller 2: vaccum/boost leak 3: blocked cat (however if this was the case it would boost up then drop back as it got higher in the revs) Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5331333 Share on other sites More sharing options...
bubba Posted July 6, 2010 Share Posted July 6, 2010 Have you got their contact details? I don't care enough to keep contact details, if you search you will find threads and I have seen one with my own eyes that came in to the workshop, exhaust wheel was still intact. By all means guys, wind your stock turbos up, I'm not the one that will be crying when they let go Link to comment https://www.sau.com.au/forums/topic/327667-max-boost-the-standard-r33-turbo-can-deliver/#findComment-5331479 Share on other sites More sharing options...
