I don't care enough to keep contact details, if you search you will find threads and I have seen one with my own eyes that came in to the workshop, exhaust wheel was still intact.
By all means guys, wind your stock turbos up, I'm not the one that will be crying when they let go :banana:
No one's doubting that it 'can' happen. But the back end is more likely to go before the front end.
And no one is winding up turbos or crying about it. The topic of 'safe' boost levels for these turbos has been covered a million times before. The question was how high can one go?
  • Replies 71
Posted Images
Hi there,
Interesting read .. and the discussion went quite broad :banana:
As for damaged standard turbos, have a look at my signature ..
It's actually a link to some videos.
Click on the second video from the top titled 'Suspension, PowerFC, New Turbo'
There's a good coverage of what is likely to happen to the turbo.
Cheers,
Andrew
black screen, downloaded at 500kb/sec for about a minute and then i gave up. meh. sorry dude your website sucks i'm not waiting for that shit :banana:
black screen, downloaded at 500kb/sec for about a minute and then i gave up. meh. sorry dude your website sucks i'm not waiting for that shit :yes:
Sorry mate ..
Sucks and Shit?
:):ph34r:
User Error!
The page is perfectly alright.
Get your system/browser up to date.
For Netscape/FireFox you need a plug-in since the content is based on windows media.
There is a note about this on top of the page!
Or use Internet Explorer!
Edited by Torques
Good videos but the speed is limited to 120kb/s, bloody annoying when its a 70mb video and you've got a max download speed of 2.2mb/s
Hi ...
You are right!
There seems to be an issue with the provider ...
The video normally starts after 1-2 seconds and it is very smooth!
Please try again later!
Here (in London) it is very slow as well.
Sorry about that :ph34r:
Edited by Torques
Based on the HTML source, I'm guessing the videos themselves are just plain embedded files, so they're likely coming over HTTP. As HTTP runs over TCP, there is going to be maximum throughput on that single HTTP connection purely due to the latency. As the site is hosted in the states, and most people on SAU are in Australia (and you're in London), there's a reasonably high latency (250-300ms+) which is where the throughput limitation stems.
Yeah I pulled the links out the source and used a download accelerator, managed to get 2.2mb/s that way by using 10 connections. I HATE embedded videos unless they are using youtube, anything else sucks balls, always prefer a direct link to download with.
Edited by Rolls
Yup, pretty much spot on. Heh - as you found out, the only real way around it is multiple connections (cos whilst each single is limited by the latency, by establishing multiple connections you overcome that). This is also why torrents work so well :ph34r:
... anyways, back to your regular channel now </end geek>
Anyhow, enjoy watching.
:ph34r:
A lot of the videos appear to be from some DVD or something, because at the end they go 'next episode' etc, what is this dvd as I wouldn't mind watching them all, not just your bits you've cut out.
Thanks
Many years ago on a previous r33 the pressure line going to my actuator pretty much open.. Not sure exactly how much it was running but it would have been a bit over 15psi - used to go off the stock gauge. Back then i thought +7 meant 7psi haha!
Drove it hard for over 20,000kms before realising why my stock car went harder than everyone elses :D Eventually put it back to stock boost, i had the turbo off after all of this and it was perfect condition.
Not saying this is the norm, but thats an example of good luck i guess.. Those were the good old days, ignorance was bliss!
did you have a stock ECU?
how did you do this with not hitting Rich and Retard
Stock ecu! Over the years I have seen that most cars hit r&r, some dont. My current car hits it at around 9psi when I try the stock ecu but my old car didnt. May have been messed with, who knows but it looked untouched.
Drove it hard for over 20,000kms before realising why my stock car went harder than everyone elses :P Eventually put it back to stock boost, i had the turbo off after all of this and it was perfect condition.
:D
After all the gloomy replies and off-topic posts this is an uplifting story :P
I can literally see you in your Skyline with the boost over 15PSI and not thinking a moment about destroying the turbo.
Yes, ignorance is bliss and for some reason not every R33 turbo explodes if taken to new levels.
Cheers ...
Edited by Torques
:laugh:
After all the gloomy replies and off-topic posts this is an uplifting story :laugh:
Cheers ...
haha happy to hear mate :laugh: Didnt have a worry in the world - I had some of the best times in that old car.
I personally know a few people who have run around 13psi for a while with no issues, if you speak to tuners im sure you will hear some say 10psi and others say 13-14 is fine. Personally I believe that there is more to it than just a value.
I believe both heat and turbine speed may come into the equation, hence say you have a rich tune and only boost for short periods then I wouldnt expect the turbo to go easily. On the other hand - say you run a leaner tune and use it on the track where you have full throttle a lot of the time....
So if you use your car on the street and give it a quick squirt here and there, dont rev it out often, then I would not be surprised at all if the stock turbo lasted a long time as I have experienced myself and seen on other cars.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
