Hi,
I moved house on the weekend and dont have room to keep this motor around AND work on my car so it has to go cheap cheap.
Its an RB25DET from an R33 Series 1, in great condition, comes with loom and ecu. It has a standard turbo and dump, standard injectors, it has a custom forward facing plenum. Rocker cover and timing belt covers have been resprayed in 2pac maroon, looks schmick. Its complete with all ancilleries except for the alternator and CAS as I sold them.
Im in Kensington/Randwick (NSW), I also have an engine hoist so it can be easily loaded on a ute or trailer.
PICK UP ONLY or can send it so long as the courier picks it up and packs it, I dont have anything to put it on ie. pallet but I can help load it onto their truck etc-
*number removed*
$1300
If you're willing to part (sort of) would you be willing to sell the front facing plenum, for my stock plenum + cash?
I pay shipping both way, and some cash ontop of my plenum?
sorry not worth my effort, selling cheap so it's out of here, otherwise I'll part it out and eBay the lot
    • Sell it and buy something newer? 馃槢
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
