Hey guys,
I got my r33's apexi neo tuned at allstar garage last week - the result was 260rwhp
When i picked the car up one of the guys told me that there is a drop in power through the mid range and that this is normal for an rb25 and the only way to get rid of it is with a full computer - however after doing some research I have seen dyno graphs of Rb25's with safc tunes that dont have this dip in the power curve???
i have attached my dyno sheet and am looking foward to hearing your comments - its annoying to drive with the dip in the mid range and your basically sitting wait for the power to come...
Comments/ Advice?
Steve
https://www.sau.com.au/forums/topic/327690-weird-power-curve-after-dyno-tune/
Seriously... It's rich and retard, when the AFM reads a certain amount of boost (being too high) it pulls heaps of timing out and adds lots of fuel!
You can clearly see on the graph that the boost just spikes a little in the midrange and then car dies in the ass, get a aftermarket computer to solve your problems :P
ok i will look into this - i have seen other rb25's with an safc tune that dont have this problem??
should i turn the boost down 1 psi to avoid entering R &R mode for the time being? im keen to head down to the drags but i think this may mess up my times a bit.
  • Like 1
+1 you can even see where the boost drops back down the curve recovers itself
I really doubt you'd notice a 1psi drop but it may be enough that it no longer hits the airflow cut, but really.. if you're worried about 1psi affecting your times, what do you think a big dip in your curve is going to do to your times??
Edited by bubba
sorry mate i meant i was worried about the dip in power affecting times and therefore considering dropping it 1 psi to avoid it... noob question but as the car has been tuned to whatever psi its running at the moment, if i simply drop it down 1 psi do i need to get it re tuned to this boost level?
1psi won't make a difference to your tune, and i dont think that 1psi will make the difference so stop rich and retard, so I'd suggest dropping the boost by 2psi increments untill you feel the car has a smoother power band and it's not hitting r+r anymore.
perfecty normal for 33s. the safc will help a little but you cant completely get rid of it when running higher boost without an aftermarket ecu. the small rise in boost is normal too, its from the stupidly retarded timing around that part of the map
this is my 25 when i had a stock ecu, was like hitting vtec
Edited by JonnoHR31
It's an airflow cut anyway, 8psi on one stock 33 turbo isn't going to be quite the same as another stock 33 turbo, especially when you bring china fmic/piping and other individuals setups into the equation. Boost is just a measure of restriction afterall.
Edited by bubba
exactly. and its not a sudden thing, it'll gradually get worse with more airflow. you could even say a 100% stock car is hitting r+r as it runs a little rich and the timing isnt optimum. or from another point of view you might not call it r+r until it takes less than 1 tank of fuel to turn your white rear bumper black and the combustion event is happening more in the turbine housing than the cylinder
+1 for nistune
