Hey guys,
I got my r33's apexi neo tuned at allstar garage last week - the result was 260rwhp
When i picked the car up one of the guys told me that there is a drop in power through the mid range and that this is normal for an rb25 and the only way to get rid of it is with a full computer - however after doing some research I have seen dyno graphs of Rb25's with safc tunes that dont have this dip in the power curve???
i have attached my dyno sheet and am looking foward to hearing your comments - its annoying to drive with the dip in the mid range and your basically sitting wait for the power to come...
Comments/ Advice?
Steve
https://www.sau.com.au/forums/topic/327690-weird-power-curve-after-dyno-tune/
Seriously... It's rich and retard, when the AFM reads a certain amount of boost (being too high) it pulls heaps of timing out and adds lots of fuel!
You can clearly see on the graph that the boost just spikes a little in the midrange and then car dies in the ass, get a aftermarket computer to solve your problems :P
ok i will look into this - i have seen other rb25's with an safc tune that dont have this problem??
should i turn the boost down 1 psi to avoid entering R &R mode for the time being? im keen to head down to the drags but i think this may mess up my times a bit.
  • Like 1
+1 you can even see where the boost drops back down the curve recovers itself
I really doubt you'd notice a 1psi drop but it may be enough that it no longer hits the airflow cut, but really.. if you're worried about 1psi affecting your times, what do you think a big dip in your curve is going to do to your times??
Edited by bubba
sorry mate i meant i was worried about the dip in power affecting times and therefore considering dropping it 1 psi to avoid it... noob question but as the car has been tuned to whatever psi its running at the moment, if i simply drop it down 1 psi do i need to get it re tuned to this boost level?
1psi won't make a difference to your tune, and i dont think that 1psi will make the difference so stop rich and retard, so I'd suggest dropping the boost by 2psi increments untill you feel the car has a smoother power band and it's not hitting r+r anymore.
perfecty normal for 33s. the safc will help a little but you cant completely get rid of it when running higher boost without an aftermarket ecu. the small rise in boost is normal too, its from the stupidly retarded timing around that part of the map
this is my 25 when i had a stock ecu, was like hitting vtec
Edited by JonnoHR31
  XxNinjaxX said:
if it helps, though testing on my own R33 i found 8psi to be the maximum boost you should run on the standard ecu to safely avoid the R&R + fuel cut while still having decent power :ph34r:
8psi ? :) Can easily go higher than that.
It's an airflow cut anyway, 8psi on one stock 33 turbo isn't going to be quite the same as another stock 33 turbo, especially when you bring china fmic/piping and other individuals setups into the equation. Boost is just a measure of restriction afterall.
Edited by bubba
exactly. and its not a sudden thing, it'll gradually get worse with more airflow. you could even say a 100% stock car is hitting r+r as it runs a little rich and the timing isnt optimum. or from another point of view you might not call it r+r until it takes less than 1 tank of fuel to turn your white rear bumper black and the combustion event is happening more in the turbine housing than the cylinder
+1 for nistune
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
