R34 Gtt Coupe Manual Hks
After spending months and months to find a R34 GTT like this, i now have to sell the sexy thing. It is simply my loss and your gain. If you are looking for a R34 then this is your chance, the best you can get for your money.
Skyline R34 Gtt in black coupe, manual with only 79xxxkm genuine km
This skyline literally took me more than 6months to find. I never go for cheap dodgy things and with skylines as most of us know theirs a lot of dodgy ones out their, so i looked at almost every R34 on carsales and couldn't find a better one than this. No accident history at all, very clean and well taken care of.
Since i bought another car, this baby is rarely driven. Even tho i barley have time to drive it but i have to drive it once a week because i really do get to miss it. At the moment its sitting in the garage waiting for its weakly wash and clean, and now the time has come to pass it to another skyline enthusiast since i need the money.
This car has had a lot of time and money spent on it, almost $20,000, which i have receipts for most of them.
Some of the modifications are:
- HKS gt-rs ballbearing turbo
- HKS SSQV
- Apexi N1 filter with full piping
- Nismo super light fly wheel
- Exedy heavy duty clutch
- Kakimoto Mega N1 3.5' turboback exhust
- Nismo header
- HKS hypermax front adjustable coilovers
- koni rear adjustable coilovers
- Blitz 18' super light weight wheels
- Nismo front strut brace
- Cusco rear sway bar
- Viper 5902 alarm
- JL speakers all around.
- Factory full Nismo bodykit.
-Modifications done by Racing Project with receipts in OCT2009
-One of a kind car, and very well looked after.
-Serious buyers only
-If you are looking for a honest R34 that is not dodgy, this is the one.
Comes with RWC and rego till end of the year.
Genuine reason for sale, make me an offer.
$21450ono
Please don't comment unless your interested or have something good to say. Thanks
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
