im think a boost leak, but it feels like a pretty solid 5psi that im getting when i full throttle it, i have an aftermarket boost guage and the one in the dash still works, they both read about 5ish psi, if it was a leak somewhere wouldnt the boost slowly die down? instead of a stable 5psi?
the solonoid is bypassed fyi
any help as to why this is, is apreaciated
https://www.sau.com.au/forums/topic/327780-max-5psi/
Check the intercooler pipes and clamps?
Failing that, try plug the solenoid and see if it goes to 7psi.
Other than that, I don't have any idea - been a while when I last messing around with GTST.
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5331299
most likely failed attempt at bypassing the solenoid
take a picture or tell us wht you have . do you have a hose going straight from the ic pipe to your wastegate
and car is apparently running fine/fast so its most likely not a boost leak
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5331334
if you bypass the solenoid and run boost directly to the actuator you should get 5psi, they're a 5psi actuator afaik. replace the solenoid and wire it for a constant 7psi
that is incorrect
as per the nissan service manual
Use the air gun to blow compressed air approx A ~ B kgcm2 into the hose and make sure the swing valve controller rod operates.
where
HR32 - A = 0.8 and B = 0.9 kgcm2 which is 0.85kgcm2 (average) which is 12.08 psi
BNR32 A = 0.7 and B = 0.8kgmc2 which is 0.75kgcm2 (average) which is 10.66 psi
ECR33 manual is 385mmhg which is 7.4446 psi
ECR33 auto is 270mmhg which is 5.220 psi
BCNR33 A = 0.79kgcm2 and B = 0.85kgc2m which is 0.82kgcm2 (average) which is 11.6 psi
if someone can find ER34/BNR34 please let me
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5331721
how do i wire the solonoid? the solonoid is still in there, but not sure what you mean on "wireing" it. im happy with a constant 7psi, but i dont want 5 psi, or even the 2 stage boost thats stock on the r33, constant 7psi for me thanks :ph34r:
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332708
that is incorrect
where
awsome info, but mines a manual :S
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332711
ok ill try get one tonight if it isnt dark when i get home
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332719
Are you certain your gauge does not read in Bar/KPA, as .5 bar is roughly 7psi...this would explain why you think it's only running 5psi?
If that's not the case, it sounds like the solenoid bypass has been done incorrectly...perhaps try looking at diagrams of it on these forums and then retrying it. Black wire should be earthed (may have come loose) and the other end of it coming from the solenoid should be taped off properly, or you may end up with a permanent 5psi.
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332864
something is wrong, even if you bypass it in correctly, the actuator spring is still 7psi
so no matter what you do, the minimum boost is 7psi before it opens
where are you measuring 5psi from?
what guage? where is the signal coming from? what is the guage displayed as
what mods after the compressor outlet?
ie: poor intercooler? leaking pipework? poor joiners? mangled vac lines? poor boost guage?
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332892
Blocked/collapsed cat? when the cat collapsed in my wagon it was causing horrendous boost issues. Swapped out the boost controller, the solenoid, the wiring, put my RB20 actuator on, still couldn't get over 5-7psi.. dropped the exhaust to take it for a spin and found the cat had collapsed.
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5332934
where are you measuring 5psi from? on the front side of the intake manifold (not the rear/cabin side)
what guage? where is the signal coming from? what is the guage displayed as from both asftermarket guage (which is definatly psi not kpa)
what mods after the compressor outlet? stock dump, stock front pipe, 3.5 inch cat back, fmic, stock airbox
ie: poor intercooler? not sure, but if it was leaking wouldnt the psi fluctuate?
leaking pipework? same as above (i have checked all ring clamps are tight)
poor joiners? joiners seem in good nic aka no rips etc
mangled vac lines? which vac lines do you speak of?
poor boost guage? boost guage is a cheapo auto meter or something, looks el cheapo, but the dash boost guage reads similar
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5333052
its pretty hard to pick 5psi vs 7psi on the stock guage let alone on an el cheapo
i recommend if you really want to be sure is read the boost pressure at the compressor outlet
you may find its 7psi at the compressor outlet, but after the compressor snout it tails off
you might find poor intercooler which is causing a pressure drop across the core
something doesnt add up, the basics of the GTST give you a 7psi boost
https://www.sau.com.au/forums/topic/327780-max-5psi/#findComment-5333123
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
