Anyone know where to get the valve cover washers for RB26? (13268-58S01/A)In my country Nissan quoted me USD140 for a set of 20.
I don't wanna sound cheap but 140 dollars for plastic grommet is bloody ridiculous. Has anyone got any luck with an alternative that works and last and i would appreciate it if anyone know where i can get these cheap online and ships worldwide!
Thank you in advance.
https://www.sau.com.au/forums/topic/327782-jesus-christ-valve-cover-washers/
what about the bolts to go with them??? I want pretty new bolts to go with the pretty new undistorted washers...
have you tried cleaning it with degreaser and brake cleaner? I personally use degreaser, then soak it overnight with vinegar and finally another night with softdrinks, eg:pepsi/coke before finally rubbing off any extra residue with a combination of autosol and wiremesh.
Edited by rych
Yep they are bloody pricey for what the are so I made mine out of ( believe it or not ) tap washers and they dont go soft and wear out like the stock ones ! They are like $22 for 20 of them from hardware outlets. Just get the ones with the yellow washers on them !
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
