Sau:nsw Wakefield Groups & Info Thread
S13Deviat
 Share
  • Replies 111
Posted Images
Hello,
Finally registered my own account (was previously using my friends account, akajonz).
I'm really looking forward to this! and have been edging to go for weeks now.
I'll be driving a honda, so please be gentle on the straights. 120kw ftl :D
hey Ando, thanks for organizing, well done. :laugh:
Quick question, maybe i missed it, is there any seperate passenger sessions or are they along for the ride in the various groupings.
Looking forward to the day and hope the weather is kind to us.
cheers Ron
dont encourage him to do that, he is in our group, that means less track time for us.
:laugh:
Don't worry, I have no plans to go play in the sand! :laugh:
I do however plan on geting an award for "Seriously Cass, fix your f**king car or we will ban you from life!" or to the same effect :laugh:
Dah, I wanted to go head to head with Reece. If my times come down I'll see if I can move to group 1 on the day.
Not what the day is designed for, going 'head to head'. Sorry mate, i have to be very clear that this is a 'driver trainer day' and we will not accept any form of racing, we are not covered for that and the whole reason we are allowed passengers!
There will be no bumping up of cars because of 'times' as it is a non-timed event. Only movement will be if there is a clear mis-match of speed between cars in a particular group.
Ron - Mate, passengers are able to go out in every single session, all day long :laugh::laugh:
What about overtaking? Will we be allowed to overtake anywhere?
Also, can we get there 7:00 ~ 7:30 for scrutineering? Or only at 8:00?
Edited by Tonba
yes can overtake, but when it is safe and the slower car will still hold the line, faster car is responsibile for passing.
no passing/diving under brakes.
all this will be discussed on driver breifing :laugh:
my two cents;
if you are finding yourself right on the back of a car and wanting some room, an option is to just come into the pit entry. drive SLOWLY down pit lane and back out onto the track at the pit exit (make sure you have the wave-on from the pit exit marshall). this puts you on the opposite end of the track of the car you were hounding and you dont have to worry about executing an overtake. just a thought.
also, many thanks ando! looks great
also, possibly a dumb question but group 5 is first. they followed by group 4 or group 1? groups running 1-5 but with 5 first or 5-1?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
