hi guys,
i had my diff rebuilt with new bearings, seals & new nismo shims for my r32gtr (2 way diff).
prior to having it rebuilt, it used to make a humming noise between 60-90km...since the rebuild it makes the same noise but not as bad.
what could this be? maybe the fresh oil helped with some of the noise?
or is it normal for a 2way diff to make this sound?
if i have the radio on medium level i cannot hear the diff, im just really fastidious when it comes to my gtr :banana:
thanks
marko
https://www.sau.com.au/forums/topic/327845-recent-diff-overhaul/
Generally speaking, period noise (noise only heard at a certain speed, etc) is caused by crown wheel & pinion wear.
It can be quite easily missed when building the diff as it is not always noticeable (unlike pitting, etc)
It can be very slight wear, not much different to normal running marks, but enough to cause noise.
A thicker oil after building could have slightly improved the noise but won't fix it, as you've found.
If this noise was one of the things you mentioned you wanted fixed when talking to the place that built the diff maybe talk to them & see if they would consider looking into it as warranty...
i had terry @ award diff build it for me - nice guy & knows his shit!
i'll speak to him tomorrow, he initially thought it could be a half shaft that might have twisted when i ran it @ the drags but i i think its gears itself, i.e. worn gear set
i wonder if adjusting the backlash can eliminate the noise, maybe if it was running a bit looser it will let more oil in between the gears?
if you run it at the drags increasing the backlash could cause more damage. as wlspn said, i would be looking at wear on the crown wheel and pinion as this is what usually causes that noise at that speed. ask terry if he took a reading of the tooth contact, being as good as what you say he is he should have seen the reading and noticed it was out
Once a diff starts whining that is it, it will never be quiet again. It is almost always caused by wear on the crown and pinion teeth, a common cause is people putting a diff back together and not correctly setting the backlash, this causes accelerated wear which can turn a silent diff into a noisy one in just a few kilometres
Changing the oil can decrease the noise ever so slightly, but it will never work miracles, this is most likely what has happened with you.
Edited by Rolls
