Richmond To Bathurst Cruise!
GTRsean
 Share
Richmond to Bathurst and back Cruise!!
What: A nice Saturday drive to Bathurst and a few photos too.
Where: Meeting at the RAAF Base Richmond carpark on Percival Street
When: Saturday 10 July 2010
Time: 9:30am for 10:00am departure
Parking: Meet point parking is free.
Note: Make sure you have a full tank for the trip and some lunch/fuel money.
Weather forecast for Saturday is mostly fine and a top of 19degrees.
There will be no tolls and we will be taking Bells line of road. Also there is a point to point speed camera in place between Lithgow and Bathurst.
- NO burnouts
- NO inappropriate behaviour
Route and other details will be discussed on the day.
Hope to see some of you enthusiasts there! :banana:
  • Replies 46
do we have an estimated time of arrival at bathurst?? I have to be back in penrith by like 4:30...
Takes at the most, 2 hours to get there.
you coming along michael?
wouldnt mind coming to see u guys again, im from sutherland shire so its a massive trek for me, may be in weather pending...
whats the best way to get to richmond from my area ?
not sure on what route to take to get to richmond,
Just search on google map or windsor rd takes you here. :D
I might come along weather pending.
weather should be fine *touch wood*
Will be good if ya can make it but :cool:
Edited by Sloane
Michael,
Princes Hwy > Sutherland > Bangor > Left at New Illawarra Rd > Right at Heathcote Rd > Left onto M5 > M7 > Richmond turnoff.
Michael & Raf,
Weather report is FINE! No showers till Sunday.
Anyone here want to buy tickets to the R32 GT-R 21st B'Day at the START?
I can only come to the Start - sorry.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
