Haven't had any interest in car so just selling engine, if no interest in engine then I'll start parting it out. Heads up that I don't have much spare time to pull it down so please understand the big bits will be sold first and small parts last if it comes to it.
Car has made 465hp @ wheels, had a lot of fun building it but haven't got the time or money to put it to use. In the time its taken to build I've gone from a single full boost hoon to a happily married sedate loving father. Having two kids under two years old makes it a lil hard to get out to the track and I'm not one for a Sunday drive anymore. If not sold as package I will keep some bits so I can put a stock motor in for the odd hill climb or to sell the car.
Whole lot $13,000 (should be everything you need for conversion to RB30/26)
Happy to hear serious offers
Engine: ($9,000)
-RB30 Block/Crank with turbo water/oil threads
-RB26 Head
-Precision Rods
-ARP rod bolts
-ACL race bearings
-ARIAS forged pistons
-Tomei oil pump
-Jun crank collar
-4 layer MLSR steel head gasket
-1mm head oil restriction and one blocked off
-std GTR cams
-1inch custom head oil drain
-Head ported by Darren at Lewis Engines
-Modified larger sump with head oil drain and catch can inlets
-std GTR plenum, inlet manifold and throttle bodies
Turbo kit: ($2700) has done aprox 10,000km
-Garrett t04z (0.84 rear, 0.70 front)
-Trust high mount manifold
-Trust waste gate
-Water/oil lines
-Greddy Y intake
Electronics:
-GTR engine wiring loom (modified to suit R32 gts-t) $500
-Power FC D-jetro (hand controller, map sensors, R32 GTR plug ecu) $1000
-800cc SARD injectors ($800)
Other: (only for sale with engine as a package)
-R33 5 speed with modified speedo sender
-5 puk clutch
-Custom one piece tail shaft
Thanks people
  • Replies 49
Posted Images
I made the catchcan, 4 liters works well. Wasn't intending to sell it but I also didn't think I'd ever want to sell the engine. Let me know how much you'd pay for one and I'll think about it. Might even see if I could build another.
I did a compression test a couple weeks ago and thought the compression was a little low and I just found out why, there is a rubber o-ring missing where the spark plug thread adapter screws on, without it it screws up to far. Also just been told that I should be doing the test hot with all spark plugs out and throttle open which I wasn't doing before so I'll give it another try this weekend.
Power FC not sold, got a bit ahead of myself.
Price change to $12,000 ono for complete engine package
Price change to $17,000 ono for full car
Compression test redone, much better, pics attached aprox 150 over all. Engine was about 50-60degrees so not hot but still warm and throttle was held open unlike last time.
Also found video of last event I did, just small mucking around stuff.
Edited by =premo=
17psi, engine would be able to make more but that was max fuel. Need to upgrade fuel pump and fuel lines but I believe it already needs a stronger gearbox with this much power.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
