I just came back from the dyno and my GTR did a nice 260 whp at 12 psi with GT-SS ( sarcasm :ph34r: ). My tuner said I NEED to change my cat, we found some piece of the cat on the ground it's really block.
What are my option !? I don't want some cravy 600$ sard or nismo cat. I want to keep the oem look. So, I was thinking about buying a high-flow cat and weld the heat shield on it so I can keep that oem-look.
What do you guys think?
Why do you want to weld the heat shield onto a hi flow cat? Its not like there illegal, people only weld the stock heatshield on when there using a stright pipe to make it look stock.
Hey Cobraa,
If you have a look on Ebay, there are a couple of cats, the main one manufactured by a workshop in western australia that are reasonably cheap $200 - $230 in 4 or 5".
They use 100cpi metal matrix if i remmember correctly and these should flow sufficiently for your GT-SS's and at that price if your really chasing the power you can probably afford to knock the internals out for use on the track :D
I'm after one too
AFter researching Just Jap have the most resonable stock.
Catco/Xforce $175 each bolt on.
450+CFM. $370 for the 700CFM.
I'm probably gonna get the xforce $175 one
*edit btw Catco ones COME with the heatshield.
*edit again, there was a dyno done somewhere, hiflow vs testpipe. No HP difference. Obviously crap cat vs highflow/test pipe would be obvious. So just stick with Hi flow for legality purposes.
There was a test done. Something stupidly low
lame! makes me want to remove mine again, but right now it's the only thing holding back the annoying drone at 2000rpm
X-Force 3" Stainless High Flow Cat
it flows up to 570 cfm...
anyone know what a stock cat would flow roughly?
I got one of these on my r32 gtr making 205awkw @ 6000rpm with just exhaust, pods and 14psi. Seems to do the job good for the price!
I would also like to know this!
My muffler shop told me about magnaflow cat.. but that 175$ catco seems right too. Don't know which one flow better.
http://cgi.ebay.com.au/SS304-4-High-Flow-M...=item2c51eb3c08
Have a look at that bad boy.
Straight pipes all the way mate
I actually run a high flow catalytic converter business, which drastically increases the flow through the unit whilst retaining the standard shell :)
