Hello again,
A while back I wrote in to say I was thinking of putting a RB30 motor in a small Toyota bus. I got lots of very good advice, thank you, but it left me with lots more investigation to do. Well, to cut a long story short, I went through just about every engine combination recommended (or possible), but I kept coming back to the RB30. It came down to a two things: (1) the RB30 has a terrific reputation and (2) the diff ratios available to me were just too low for the bigger holden V6s or a Ford straight 6.
Finally, after a long trip on the original 2.4 litre a month back it struck me that the RB30 would have HEAPS of power for the job, so I fished around and found a pretty decent 88 model skyline with 200,000km on it, registered and in very driveable condition. Aside from one sticky lifter and a slighty rough shift on the auto, it seems good, and it is in having the auto serviced now just to be sure.
Assuming they come back to me and tell me it is ok, I will be fitting the engine and auto in the bus this weekend. But it has occured to me that the shift points on the auto might be a bit out. On the one hand it will be pushing around the equivalent of the old Pajero in weight, with a lot less rolling resistance but more windage, on the other hand it will be doing so with a lower diff ratio, working out at 2600rpm at 100km/h.
So can anyone tell me if it is possible to reprogram the auto computer on these? From what I have read it seems that I have a series 2, and I have read that these use the engine management computer to control the auto. I can see how to reprogram the injectors etc in the engine, but I can't see any reference to reprogramming the shift points.
Thanks you,
Matthew
P.S. At the end of the process I will have a very stripped out 88 skyline to dispose of, from the north west peninsula of Adelaide, and it is too good to throw away. I'll be open to offers.
dont go exactly off what i say but, you will need an aftermarket computer, they can do everything, i remember speaking to someone in regards to ecus for fords and they can adjust the point in when the gear changes, i doubt you could change a stock ecu
Right... sounds like it will best if I see how it goes then.
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
