R34 Gtt 4 Door. Nice Mods, Great Cruiser.
Item Summary: R34 GTT 4 Door. Nice mods, great cruiser.
Condition: Used
Reason for Selling: Wanting a manual.
Asking Price: 15000 CASH, 17000 SWAPS
Delivery Methods: PickUp
Contact Info: PM me, will give mobile to serious buyers.
Extra Information:
Rb25det Neo 6
4 speed tiptronic (No point having a manual in something that picks up speed this quick.)
High flow turbo (To force even more air into the beast.)
FMIC (Just to make sure that extra air aint too hot.)
Turbosmart incabin boost controler (10psi)
Bosch Pump (To force more fuel up to the engine.)
Sard FPR (To keep control of all that fuel from the bigger pump.)
Bigger Injectors (So all that extra fuel can actually get into the engine.)
Reinhard 3" s/s exhaust from turbo back
Python Alarm, has remote start and all that shit
8k HIDs (low beam only)
Ohlins 36 dampener coil overs ( Top of the range, fully adjustable...Height, Dampener, Rebound.)
18" Speedy Cheaters (18x8 fronts and 18x9.5 at rears to help stop uncontrollable wheel spin from all the power.)
A/C is cold as ice and the heater works a charm (climate control)
Power windows
Around 10% window tint
Stock guages have been replaced with alot nicer looking ones.
This is is a great cruiser, on a full tank this car yeilds around 400kms to and from work
which is all its used for. On the highway youll see an easy 500kms to a tank. Pulls great,
cops leave you alone, defect free, jump in and drive to Melbourne without any hassels.
Bad Points:
-small dent in rear quater panel, nothing major and would be an easy repair with no paint needed.
-couple of scuffs on paint but overall paint is great condition.
-some scratches on interior only near gear selector, rest of interiour is great.
-Fake carbon fibre on pillars is faded as seen in pics. (In process of getting removed.)
These go for around $20,000 especially with all the mods this has, but price has been lowered to allow for the couple of minor bad points so please keep any crap out of this topic as it will just be reported and ignored.
I am after a cash sale or Swaps for something manual around the value of $10,000 and cash my way. Either straight swap or swap and cash my way. Anything Import, R33's, R32's, WRX, Forester, 180, s14 etc. or BA XR8, BA XR6 Turbo etc....throw me some offers.
Cheers.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
