so i did the coke can mod tonight and seemed to get rid of the farting issue... How bad is it not having the blowoff functioning? Should i look into the grub screw mod?
There is mechanism why it may not be good..
But its pseudoscience at best no one really knows and there are many people on either side of the fence... Personally i have never run them in any of my drift cars. 20+ psi. Had no dramas.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6321758
yeah well we purposely never ran one on the CTS Drift Car as we found it held the boost better that and the fact it was one less part we had to worry about failing. But i was just worried on a stock car such as these it might have some issues. i guess ill wait n see...haha
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6321888
  • 2 months later...
Docile... that was not problem when I did that mod.
I found it good when on of off the throttle but when cruising on the Highway at 115kmh it tended to stutter and was very uncomfortable. Had to stop on the trip to remove the grub screw. Fortunatley it only takes 5 minutes to remove.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6430199
Did the coke can mod. Very straight forward.
Great results; eliminated the farting, seems to be slightly more responsive, got the fully sick VL flutter sound which is manageable. Certainly turns heads when people look that it is a wagon.
  • Like 1
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6434040
As Andy mentioned, wait till you take it on the highway. Drives like a dog.
I'm not exactly sure what the fix is... but once I changed the intake and tuned it with the E-Manage I no longer get the farting... Have been driving it around for about a year with no issues.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437284
Thanks for the heads up. So far had it cruising at 90kmh at constant speed, seemed quite ok, will see how it goes over 100kmh.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437380
Take it on a long hill and when you try and maintain a steady speed. When you ever so slightly back off the car will begin the shudder.
It drove me nuts. That and the stupid sound. Would be fine if it was a 1000kw beast... but its a wagon... with alot less power.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437929
Took it for a drive today across Melbourne (Moorabbin to Geelong and back). Kept it steady at intervals of 90kmh, 100kmh, 115kmh and 120kmh. If you are steady on the throttle, not like a taxi drive on/off, I could not fault it.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6439069
Have to agree. I ran mine with the grub screw for many 10's or thousands of kms on highway, never an issue.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440190
My car has the super hectik vl fluttaz, but I can't work out why. I just assumed it was an a/m bov, and never got round to looking at it.....until my turbo blew.
I've pulled the BOV off and checked all the lines to make sure someone hadn't blocked them for teh fluttaz. Do the BOV's fail very often?
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440239
My std BOV did similar, [fully hectic sound included] annoyed the crap out of me and made the car surge on light throttle transitions I took it off to check it out. Ended up having a ruptured diaphragm, I replaced it with std BOV off another VQ25det and the problem was solved, driving the car was so much better.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440307
now just wondering whether to keep it or put on a new stock BOV as I do not want to kill the turbo.....
I replaced mine with a Turbosmart Dual Port. Theo has the same one, and Scotty has a Turbosmart Kompact. Little bit of flutter but if you're smooth it's hardly noticable.
I didn't like the idea of replacing one BOV having issues with a second hand one when they're all prone to doing this.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440587
