so i did the coke can mod tonight and seemed to get rid of the farting issue... How bad is it not having the blowoff functioning? Should i look into the grub screw mod?
There is mechanism why it may not be good..
But its pseudoscience at best no one really knows and there are many people on either side of the fence... Personally i have never run them in any of my drift cars. 20+ psi. Had no dramas.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6321758
yeah well we purposely never ran one on the CTS Drift Car as we found it held the boost better that and the fact it was one less part we had to worry about failing. But i was just worried on a stock car such as these it might have some issues. i guess ill wait n see...haha
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6321888
  • 2 months later...
Docile... that was not problem when I did that mod.
I found it good when on of off the throttle but when cruising on the Highway at 115kmh it tended to stutter and was very uncomfortable. Had to stop on the trip to remove the grub screw. Fortunatley it only takes 5 minutes to remove.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6430199
Did the coke can mod. Very straight forward.
Great results; eliminated the farting, seems to be slightly more responsive, got the fully sick VL flutter sound which is manageable. Certainly turns heads when people look that it is a wagon.
  • Like 1
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6434040
As Andy mentioned, wait till you take it on the highway. Drives like a dog.
I'm not exactly sure what the fix is... but once I changed the intake and tuned it with the E-Manage I no longer get the farting... Have been driving it around for about a year with no issues.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437284
Thanks for the heads up. So far had it cruising at 90kmh at constant speed, seemed quite ok, will see how it goes over 100kmh.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437380
Take it on a long hill and when you try and maintain a steady speed. When you ever so slightly back off the car will begin the shudder.
It drove me nuts. That and the stupid sound. Would be fine if it was a 1000kw beast... but its a wagon... with alot less power.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6437929
Took it for a drive today across Melbourne (Moorabbin to Geelong and back). Kept it steady at intervals of 90kmh, 100kmh, 115kmh and 120kmh. If you are steady on the throttle, not like a taxi drive on/off, I could not fault it.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6439069
Have to agree. I ran mine with the grub screw for many 10's or thousands of kms on highway, never an issue.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440190
My car has the super hectik vl fluttaz, but I can't work out why. I just assumed it was an a/m bov, and never got round to looking at it.....until my turbo blew.
I've pulled the BOV off and checked all the lines to make sure someone hadn't blocked them for teh fluttaz. Do the BOV's fail very often?
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440239
My std BOV did similar, [fully hectic sound included] annoyed the crap out of me and made the car surge on light throttle transitions I took it off to check it out. Ended up having a ruptured diaphragm, I replaced it with std BOV off another VQ25det and the problem was solved, driving the car was so much better.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440307
now just wondering whether to keep it or put on a new stock BOV as I do not want to kill the turbo.....
I replaced mine with a Turbosmart Dual Port. Theo has the same one, and Scotty has a Turbosmart Kompact. Little bit of flutter but if you're smooth it's hardly noticable.
I didn't like the idea of replacing one BOV having issues with a second hand one when they're all prone to doing this.
https://www.sau.com.au/forums/topic/327936-m35-bov/page/5/#findComment-6440587
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
