Guy I'm attaching a heltech 2000 pro to the standard oil presure sensor getting a reading but dont know what scale to set the heltech to???? Example what voltage is say 40 pound ?????
I have the r32 gtr oil sensor
The stock gauge reads in kg/cm2, then just use: http://wiki.xtronics.com/index.php/Pressure_Conversion_Table
1kg/cm2 for example is close to 1bar which in turn is about 14.x psi
convert kg/cm2 to whatever pressure you prefer, psi, bar etc
no he means
at 1.0v what is the pressure ie 1.05kgcm2
at 1.1v what is the pressure and so on 1.15 kgcm2
it would be documented somewhere, not sure where tho
you could always use a mulitmeter and linear scale it yourself
according to service maunal at idle of 800rpm it should be 1.5kgcm2 for RB26DETT
no idea if you have std oil pump or other shit modified, but you could use that as base
ie warm up engine
drive around
come back to garage
let it idle for a minute
take that voltage as base and assume it is 1.5kgcm2 and you have fairly basic comparison
no idea if its linear or not ie lets say 1.5kcm2 is 1.0 not sure if 2.0v is 3.0kgcm2
problem is paul we are not useing the standard gauge so what we are do is inputing it to the IQ3 digi dash and that want us to give it a scale to then convert to signal the dash wants??????
Or measure it with a multimeter and have an electronic/mechanical gauge hooked up and read both for nodes throughout the range, plot this up and get a line of best fit for oil pressure vs voltage and apply this to the haltech. I doubt it would be a straight line fit.
not sure if this helps but a lot of electronic gauges have a sender unit that sends a voltage signal to the gauge, would one of them do it for you?
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
