Guy I'm attaching a heltech 2000 pro to the standard oil presure sensor getting a reading but dont know what scale to set the heltech to???? Example what voltage is say 40 pound ?????
I have the r32 gtr oil sensor
The stock gauge reads in kg/cm2, then just use: http://wiki.xtronics.com/index.php/Pressure_Conversion_Table
1kg/cm2 for example is close to 1bar which in turn is about 14.x psi
convert kg/cm2 to whatever pressure you prefer, psi, bar etc
no he means
at 1.0v what is the pressure ie 1.05kgcm2
at 1.1v what is the pressure and so on 1.15 kgcm2
it would be documented somewhere, not sure where tho
you could always use a mulitmeter and linear scale it yourself
according to service maunal at idle of 800rpm it should be 1.5kgcm2 for RB26DETT
no idea if you have std oil pump or other shit modified, but you could use that as base
ie warm up engine
drive around
come back to garage
let it idle for a minute
take that voltage as base and assume it is 1.5kgcm2 and you have fairly basic comparison
no idea if its linear or not ie lets say 1.5kcm2 is 1.0 not sure if 2.0v is 3.0kgcm2
problem is paul we are not useing the standard gauge so what we are do is inputing it to the IQ3 digi dash and that want us to give it a scale to then convert to signal the dash wants??????
Or measure it with a multimeter and have an electronic/mechanical gauge hooked up and read both for nodes throughout the range, plot this up and get a line of best fit for oil pressure vs voltage and apply this to the haltech. I doubt it would be a straight line fit.
not sure if this helps but a lot of electronic gauges have a sender unit that sends a voltage signal to the gauge, would one of them do it for you?
