Hey all,
Just a quick query for those who know more about cars than I do:
My car (1997 R33 Gts25t S2 - 78000k's) has started to make a rumbling sound - no noticeable wheel vibration (just the rear view mirror wobbles) whenever I take my foot off the accelerator at speeds of 110kph or more.
I have been told by a friend who is a mechanical fitter (not a mechanic but mechanically minded) that this could be a wornout uni joint on the tail shaft, and is something to do with it moving when not under acceleration. Something like that. I am not mechanically minded (at least not with gearboxes and drivetrains) and just want to know if this is something to worry about or to get replaced soon, and how much I'm looking at paying?
Any input would be greatly appreciated.
Cheers, Jon.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/
Is it only rumbling or sort of rattly as well?
If the noise is just rumbling & only there when coasting (backing off & rolling) there's a good chance it could be the large pinion bearing in the diff.
It shouldn't cause too many problems besides maybe metal going through the other bearings & damaging them.
But hey, if you were going to get a diff rebuild you would replace all bearings anyway so not a major issue.
Hunt around for some prices. Call in to diff/trans specialists & someone will probably be happy to take it for a test-drive, give you their first-hand opinion & a rough starting price. Depending what needs to be done when it's opened up I would expect it to cost $400+ or around there somewhere...
Probably don't really need to rush. Have had cars come in where you can hardly hear the radio over the diff noise & sometimes still only need just bearings & a set-up.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5333730
Hey Jon,
Welcome to my world, I have had the exact same issue for sometime now and it is getting so uncomfortable to go over 110+
Does yours really start to rumble/vibrate when on the gas at 100+ and then when you back off the gas it feels heaps worse?
I reckon wlspn is onto something here, I had my 1 piece tail-shaft balanced not so long ago, hardly made a difference, I had a new LSD diff centre put in 2 wks ago, problem is still there, giving me the shits I tell ya, and has so far cost me some serious dollars. Would luv this one resolved, then I am happy to continue with other project mods.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5334356
Jon,
I should also mention that the worn out uni your friend has mentioned would be a lot of people's first diagnosis for this type problem.
My 1 piece tail-shaft does not have a centre and both uni ends were recorded when balanced recently as being really good, so I reckon we can eliminate the tail-shaft altogether and move towards it being the diff for this one.
This is definitely not a problem I can live with while I own my car, if yours gets as bad as mine you will start to hate driving at that speed.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5334389
Thanks wlspn,
Will look into phoning the guys you mentioned and getting them to check it out. It doesn't rattle at all, just a rumble, and its nothing severe, just that I cant use my rear view mirror over 100-110.
Lowbro, yours sounds quiet a bit worse than mine, but I would rather fix mine soonish just in case it is something that can do damage elsewhere or as you said, become a big pain in the arse!
I'm not in Perth again until August, but I will see what they say about if it is a diff thing (sounds likely) or a uni-joint thing. I'll still get them to check the condition.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5338546
Thanks wlspn,
My car is off to a diff specialist this afternoon for diagnosis, and I will let you know what they say for my problems.
Locating an 34 sedan manual tailshaft has become an impossible task to change over from a 1 piece to a 2 piece again to eliminate or resolve my rumble/vibrations problems at 90km+
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5341606
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
