Hey all,
Just a quick query for those who know more about cars than I do:
My car (1997 R33 Gts25t S2 - 78000k's) has started to make a rumbling sound - no noticeable wheel vibration (just the rear view mirror wobbles) whenever I take my foot off the accelerator at speeds of 110kph or more.
I have been told by a friend who is a mechanical fitter (not a mechanic but mechanically minded) that this could be a wornout uni joint on the tail shaft, and is something to do with it moving when not under acceleration. Something like that. I am not mechanically minded (at least not with gearboxes and drivetrains) and just want to know if this is something to worry about or to get replaced soon, and how much I'm looking at paying?
Any input would be greatly appreciated.
Cheers, Jon.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/
Is it only rumbling or sort of rattly as well?
If the noise is just rumbling & only there when coasting (backing off & rolling) there's a good chance it could be the large pinion bearing in the diff.
It shouldn't cause too many problems besides maybe metal going through the other bearings & damaging them.
But hey, if you were going to get a diff rebuild you would replace all bearings anyway so not a major issue.
Hunt around for some prices. Call in to diff/trans specialists & someone will probably be happy to take it for a test-drive, give you their first-hand opinion & a rough starting price. Depending what needs to be done when it's opened up I would expect it to cost $400+ or around there somewhere...
Probably don't really need to rush. Have had cars come in where you can hardly hear the radio over the diff noise & sometimes still only need just bearings & a set-up.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5333730
Hey Jon,
Welcome to my world, I have had the exact same issue for sometime now and it is getting so uncomfortable to go over 110+
Does yours really start to rumble/vibrate when on the gas at 100+ and then when you back off the gas it feels heaps worse?
I reckon wlspn is onto something here, I had my 1 piece tail-shaft balanced not so long ago, hardly made a difference, I had a new LSD diff centre put in 2 wks ago, problem is still there, giving me the shits I tell ya, and has so far cost me some serious dollars. Would luv this one resolved, then I am happy to continue with other project mods.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5334356
Jon,
I should also mention that the worn out uni your friend has mentioned would be a lot of people's first diagnosis for this type problem.
My 1 piece tail-shaft does not have a centre and both uni ends were recorded when balanced recently as being really good, so I reckon we can eliminate the tail-shaft altogether and move towards it being the diff for this one.
This is definitely not a problem I can live with while I own my car, if yours gets as bad as mine you will start to hate driving at that speed.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5334389
Thanks wlspn,
Will look into phoning the guys you mentioned and getting them to check it out. It doesn't rattle at all, just a rumble, and its nothing severe, just that I cant use my rear view mirror over 100-110.
Lowbro, yours sounds quiet a bit worse than mine, but I would rather fix mine soonish just in case it is something that can do damage elsewhere or as you said, become a big pain in the arse!
I'm not in Perth again until August, but I will see what they say about if it is a diff thing (sounds likely) or a uni-joint thing. I'll still get them to check the condition.
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5338546
Thanks wlspn,
My car is off to a diff specialist this afternoon for diagnosis, and I will let you know what they say for my problems.
Locating an 34 sedan manual tailshaft has become an impossible task to change over from a 1 piece to a 2 piece again to eliminate or resolve my rumble/vibrations problems at 90km+
https://www.sau.com.au/forums/topic/327952-r33-tail-rumble/#findComment-5341606
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
