isn't the flywheel power calculated by doing the power run and then letting the engine run back down (rather than applying the brakes to slow it down or pushing the clutch in)? this allows it to measure the resistance of the gearbox, etc and then work out the loss. i'm not totally sure, but i thought that this was 1 way of calculating it on a dyno. i know that true engine power can only be found on an engine dyno, but i thought that the calculated power could be worked out, and i am assuming that this is what has been done in this case.
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5337054
in reponse to the original post..
this exact symptom happened to me where the engine effectively "shuts down" for a second very violently and then keeps on driving but you have to stay off the gas to prevent it happening frequently.
in my case it was a coil(s) starting to play up and having a giant misfire. when i upped the boost to 15psi or so, it would suddenly have a violent stall once boost got up there, so i wound back the boost and problem was solved. however in the coming weeks it started having a slight misfire even at low boost and we realised it was coils causing it. the higher the boost, the worse it got.
this may not be your issue, just another possibility. i hadn't experienced rich&retard before but i thought there was no way in hell it would respond as violently as that. it would literally throw you forward and break your nose on the dash if you weren't wearing a seat belt.
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5337438
  • 2 months later...
Hi guys,
Just try'n to look up some info. I would like to run 10-11 psi with a boost T I got ready to install. How high can I actually go before rich and retard kicks in?
Would I need to install and retune with a new ecu chip or get a different air flow meter? What actually causes it and can i get that kind of boost from the stock ecu?
I hear some people talk about an R32 actuator... does that help?
I got only a 3" turbo back exhaust at the moment and getting 8psi. A walbro fuel pump is on the way though.
Still learning...
regards,
Dan
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5466242
Hello there!
As the starter of this thread I have found out that it was not R&R, but fuel cut.
Once the ECU detects a certain load level it shuts down the engine by interrupting ignition and fuel.
Since I have started this thread I got myself Nistune and all is sorted out now.
I know a great deal more now about the ECU and I can recommend Nistune to anyone planning
to increase HP over a certain level.
Cheers ...
https://www.sau.com.au/forums/topic/328005-is-it-rr/page/2/#findComment-5466452
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
