  • Replies 72
I went out and checked both tunnels tonight and didnt see anything...
Ive seen the ones in Sydney so i know what they look like however there was nothing out of the norm?
You sure your not just seeing things Bubba?
Edited by R32 Driver
+1, went through both ways tonight to & from the cas.
Definitely there, I had just left work so I was quite sober :blink:
I'd stop and take some photos but it might look a bit sus :P will hook the video camera up though and go through slow like.
Edited by bubba
Wall mounted up high on the right hand side, big bulbous looking thing on a stainless shaft,
On friday the 1st & 2nd ones east bound set my detector off but the 3rd one didn't. This morning I went through both ways and none of them set it off (there were the same things on the west bound side, right hand wall).
I go through the tunnel every morning and afternoon so we'll see if any are on tomorrow..
They might not be radars but I find it highly suspicious, I have never seen or noticed them before and my detector has never, ever gone off in the tunnel. I'm also pretty certain it was the things on the wall setting it off as it stopped once I was ~20m past the 1st one and it started up again the same distance before the 2nd one, then stopped ~20m past it..
whatever they are, they arent issuing fines yet. The government has to publish a notice in the government gazette before it can use a new speed detection device against motorists. the only fixed device that is currently gazetted is the new combination redlight/speed cameras.
Quick google search for "Graham Farmer Tunnel Speed":
Taken from www.mainroads.wa.gov.au Intelligent Transport Systems Strategy.
"Strategy 3.4 – Support Police enforcement
activities
a) Install Graham Farmer Freeway tunnel speed
cameras when required by the Police."
Judging by that document, it sounds as if police are able to setup speed cameras in the tunnel if and when they want.
They can't do you for speeding in the tunnel based on the camera footage because they don't have a proven scientific approach to proving it.
Just to run a quick theory by you on that. If the cameras are digital by the nature of the medium they record on, most lock to specific frame rates, for arguments sake 30fps.
Whats to say they can't simply derive how many 'frames' it takes you to cover a certain distance, say from one broken line on the road to the next? They can (with quite a decent accuracy) work out how fast you were going.
It's one of the reasons that speed cameras in my area have extra triangles drawn on the road now. They take several shots and it simply adds to the case (as usable evidence) in court.
All they need is a pre-determined distance and time (which is worked out by how many frames per second a video camera is recording at).
was it ka band? if it was just k band may have been a copper behind/infront maybe?
It was K band, if it was a cop then it was a huge coincidence that it went off next to two of the suspicious units..
I would imagine they will have to do a lot of testing to iron out the bugs before anything became operational.
OR
They are something completely different.. I had a mate try to tell me they were air monitoring devices :down:
you mean those things that look like the silencer you can temp put in the end of an exhaust? they've always been there.
since before you were born
First of all, how can you have 2 first of alls?
Second of all these cameras were installed by the security guys who work for my company :) :). I can ask them the details of the "monitoring" but from what the cameras are they do not have speed recording in them.
P.S. They start out as white cameras and are sprayed black.
P.P.S. They are always heading down to sort out issues with the system. 2 of them were there until 2am a on Sunday morning I think.
Very interesting, but no-one knows what they are.. if they are air monitoring devices, why are they pointing at traffic?
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
    • That's sick, thanks for that, mine has much the same mods on a 400R. I just don't have the heat exchanger yet.   Might be worth a trip down the M1 to Syndey for a tune.
    • Mate , this is the current mods list Current Mods list (Installed) RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler AMS Alpha Performance Full Race Down Pipes ECUTEK tune form TuneHouse in Sydney .(Just over 2k) The car came with HKS - Power Editor but I had it removed for the full tune. I would say if you are using the car for street diving a proper tune would be better.
    • Interested to see any videos of this or on the dyno. Mine currently has HKS secondary cats i am undecided if I want to remove them. What did it set you back to get the tube done? And what mods have you got to get that power? I was looking at a racebox flash tune but maybe a proper tune would be better if these guys are good.
