Thanks for the clarification.
Oh and to note I dont take a moral stand one way or the other on these devices, I just wanted to see what goes down once you get caught with one.
I am pretty sure the " parking sensor " excuses wont fly with the cops./
What's the fine ?
Over East I've heard its $1000 on the spot and they confiscate it.
Ouch
I think it would be more of a charge than a fine..
Western Australia, WA - radar detector laws
Currently there is no legislation relating to radar detector use, sale or ownership. Therefore radar detectors are only legal to SELL, OWN and USE in Western Australia. Laser Jammers should be considered illegal to use, however, there is no specific law against ownership and usage would be possibly considered hindering police. This includes parking sensors that are also laser jammers.
Edited by bubba
If you get caught with one you will get charged with something under the Telecommunications Act as transmitting on those frequencies is a BIG no-no.
If you install a device with the intention of preventing the police from doing their job, you may come across some over zealous officers who are keen to go down the long path of proving your original intention was to pervert the course of justice. e.g. hinder. If you intended to enjoy greater parking ease, then you have not broken the law. It's very hard for a prosecutor to prove what your intentions were at that time. There is no need to flick switches as the sensor is constantly scanning for obstructions in front of or behind you. If it detects that it is intefering with another system it will shut itself down after 8 seconds to prevent intefering with that device. It's worth noting that many other items use the same sort of laser, e.g. surveying equipment and even (not available in Australia) Nissan's adaptive cruise control.
Ok some good points brought up there, but no real life tales of woe yet.
The parking sensor ones are a good point, but what about the old ones that are specifically made for blocking , It would be hard to plead your case then.
Many of them turn themselves off after 4 seconds, so thats another good thing going for them .
+1 on what fine would be. i dont think it would be pretty tho.
i also was thinking if u can turn it off via a switch or something in ur dash, how can they convict you?
(dont say a cop could spot it in the engine bay etc, they dont know the difference between a catch can air breather n a bov)
Just curious to see what has happened to you if you got busted using a laser jammer to overcome speed guns/Traps.
I am fairly sure they are not legal , but just wanted to hear your story as to what happened after you got pulled over/caught.
Depends on what frequency they work on. Some of the laser parking sensors work on the 904nm wavelength which is basically a 'free to air' kind of band, and means you are perfectly within your right to transmit on that frequency. If you just happened to have your 'parking sensor' working on the same frequency and it just so happen to jam their speed gun, it's their bad luck.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
