Hey people,
I have a problem with my car (R32 GTS-t) - It's not really posessed, that's just a joke. But I seriously thought it was the first time this happened.
If my car is cold (and I mean cold, like when its 7am and the windows are still frosty), and I turn right (slightly hard - not throwing it around - usually roundabouts set this off), I get a loud... 'screaming' noise coming from about where the ECU is located.
That is, a high pitched whistle that is quite loud, and most of the time stops when I straighten up, but a few times has persisted until I turn the ignition off and on again.
Is there anything to do with the HICAS in the left kick panel? Could this be the ECU?
I'm expecting jokes back but thanks in advance for any ideas on what the frig is causing this... it freaks my girlfriend out to no end...
Cheers lol!
Bobby.
Maybe a loose belt - power steering? Though usually that will scream as the engine starts. Maybe next try with the windows open to get a different perspective on if its inside or outtide.
maybe your girlfriend is screaming?
lol
on a serious note, i had a similar problem when turning the steering wheel when stationary on a cold start, on a different car, but mechanics are similar... check your belts and fluids
Thanks for the suggestions guys :D, The fan sounds like the likely culprit, it's definitely inside the car, and I usually always have the demister on on cold mornings. I'll take a closer look next time it happens.
Cheers ;)
