Alright….Regretfully it is time to sell my R34…Have to make way for work vehicle.
1998 Nissan Skyline R34 Gt-t Coupe.
98000kms
Reg till 21/11/10
White
Manual
$23000 (relatively negotiable)
Cherrybrook, NSW
I bought this car off a dude in carlingford who possibly loved it as much as I do, looked after it well and gave it a few tasteful mods.
I have continued this with regular servicing (both my brother and my dad are mechanics) and a few more modifications.
The mods:
Apexi Power Intake
Nismo Timing Belt
Split Fire Ignition Coil Packs
NGK Iridium Spark Plug
Cooling Pro Stealth FMIC
Turbotech Boost controller (at 10 psi)
GFB bov
Apexi GT Spec. Front Pipe
Kakimoto Regu.06&R Cat Back Exhaust
HKS Split Dump Pipe
Tein MONO Flex coilovers
Nismo Brake Lines
Genuine Nismo front bar
Nismo Dark clear front indicator lens
Nismo Dark clear side indicator lens
GE HID 8000K
Nismo Badge
PIAA Wiper
HKS windscreen sunstrip decal sticker
Nismo leather gear Knob
Twoway alarm, pager remote with 3 Backlight LCD Display. 4000 Meter Monitoring Range
JVC DVD head unit
HKS type 1 Turbo Timer
I got a lil crazy one day and sprayed the wheels white, sanded them back and degreased 1st, then primed, coloured and clear coated them. The car runs great and is in good condition inside and out, there is one minor blemish in the lower part of the drivers door (seen in photos). Will sincerely miss this car and hope it goes to a good owner.
Also stock parts will be included in sale. (Full Exhaust, suspension, intercooler, bov)
Steve – 0422 633 232
https://www.sau.com.au/forums/topic/328050-1998-r34-gt-t/
