bubba - speaking REALISTICALLY i wouldn't do a 3L / 1uzfe conversion to a stagea - it'd be too hard to engineer!
extend your budget further and get a crown wagon ;)
1UZFE already inside. heck yeah!
oh and to amend my aristo fetish.. seeing as i allowed myself 25K to build the car - i figure i could stretch the budget to a current model GS300
hang on a second..
it's still an aristo :P vertex GS300 front end conversion ... could still be done for about 25K i reckon... 650HP luxo beast with GS300 front. STILL cheaper tan a comodore!!!
  • Replies 147
Posted Images
so you want a boxer engine in a VW body hey?
Have you heard of a Porsche?
That would hardly be a VWRX then would it :)
Of course I thought of that but the words budget and Porsche dont really belong in the same sentence, although it has been done many times before, Im yet to see it in AWD ,
I think finding a written off WRX for parts is going to be alot cheaper than finding a Porsche..
Also in a Porsche driveline layout the engine sits further back from the wheels
whereas a suby en engine sits more between the front wheels (insert image here), would be better balanced and wouldnt stick out as much as Porsche engines often do, remember We are changing the whole driveline here not just the engine..You will also find the Early wrx driveline is roughly 2400mm same as the beetle, though with a bit wider track..Also beetles weigh in at around 800kg no doubt the Wrx driveline will add to this considerably but you could keep overall weight close to a tonne..Not that i would build it as a performance car, just for something different...
Found these while googling as well
Ls4 turbo beetle..
And the new brumby ute...
Or how about this mix..
A 32
+ a 32
= something like this..
Heres the story if you want more...
http://www.hotrod.com/featuredvehicles/hrd...oupe/index.html
Now thats engineering!!!!
Its actually volvo powered but could esaily be done with a wrecked GTR
Edited by Arthur T3
....huh? i don't get what you're asking... i don't want to do that at all!!! or at least not now haha
basically... my sexual fantasy buys me the following:
2000 build lexus GS300
2JZgte engine
single turbo kit
bodykit coilovers rims
vertex front end conversion for current model GS300
Ever wanted the engine of one car in the body of another...I know you have
So the topic here is what 2 cars would really like to merge together if you you had all the tools and equipment at your disposal..
I have always wanted to merger these 2
n742680178_1230229_3527.jpg...........
I call it the VWRX !!!
Somehow we put the Wrx motor in the back, should fit pretty easy, and plenty of room for another diff in the front, then we just change the gearbox ratios so it has 5 reverse speed s and one forward and wallah!
Something like that anyway, so let your imaginations fly and if anyone is awesome at photoshop please do what i cant... :)
  • 1 month later...
I have always wanted a Sr20 in a MX5, apparently its not overly difficult to do, the mx5 would have to have a hard top though because i cant stand convertables! I once drove an MX5 and the handling was amazing but the power was so meh so i think a light tune 220 odd rwkw from a SR in one would be magic!
One of these:
Into my:
Mileage same same, better weight dist, practically the same wieght, far less fussy, same same power and accepts much cheaper fuel so some economy there.
garnish with associated 6sp manual box.
walla~!
edit:: Note, that is not actually my car, mine is also an s2 33 t, but not that one.
Edited by gts-4 dreamer
the WRX/any subbie motor into beetle has been done many a time, boxers are sexy engines. and its a huge boost in power even with a standard engine. seen a few AWD Bugs online, but they are as much beetle as the V8 one thats posted here (not alot)
what ive always wanted to do is rotary my bug. just a nice throaty 13B injected engine would get a 700kg car rocketing along nicely.
otherwise a friend of mine and myself have been talking about an old 2 door XM-XP falcon with a full GTS25T drivetrain. old school cool, with vaguely new power and smoothness.
I did see a rotary bug in a magazine years ago...was pretty quick too from memory and popped wheelies...
Loving that XP idea too, wouldn't be too hard either,
Im trying to convince my bro in law to put a JZ motor in his VJ charger, but his heart seems set on an old hemi, but to do what he wants with triple webbers and all costs a packet for not alot of reward, and it would probably end up with a supra box anyways so i reckon a nice turbo JZ to match could kick ass for the same outlay and upset the purists... :P
Edited by Arthur T3
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 馃槢   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When鈥檚 the tow ball on the 33 coming? 馃檭
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
