did my diff oil today, not too much problem, bolts were fairly easy to take off..
Read somewhere that the diff takes about 1.9 - 2L.. I had the car on level ground with a hand pump siphon but could only manage to get about 1.5L. I tried pumping more in but it was dibbling out quicker than i could get it in.
Should it still be ok?
https://www.sau.com.au/forums/topic/328114-diff/
Yep it takes about 1.5 - as long as it continues to come out after you've pumped it in then you're sweet :D
Use an 80w90 for a mostly street-driven vehicle, and circa 85w140 for a track car. Does not need to be LSD fluid for a standard viscous GTS-T diff.
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5354352
what diff oil did you use? i was looking at doing mine soon.
used castrol SAF-XA rear axel diff oil 80w90, took about 1.5L
get a hand siphon off ebay its like 10 bucks, it saves soooooooooooooo much time.
birds - yep it was coming out quicker than i could pump it in so figured it was full
havent really found much difference doing the diff oil - it doesnt shudder as much if anything
Edited by defari
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5357807
You probably won't notice much, it's not much of a human interaction device like the gearbox where you can feel through your hand the difference between different oils and fresh/old. Also, diff and gearbox oil can last a long time as it is not exposed to much in the way of contamination like engine oil is. Were you just doing a service interval change or were you trying to fix a diff problem?
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5357906
just a service. Had no idea when it was last done / ever done by previous owners. Got all the oils cheap too.
The GB oil change though has made a difference, although the gb never crunched etc, i did it for the same reason as the diff (wasn't sure when it was last done) The gearbox was getting a bit "whiny" in the first 5mins of driving in the morning - the whining noise is somewhat gone but can still hear it slightly however i noticed the car wasnt as jerky when i was getting on/off the gas. Also the gears just felt more "solid".
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5358234
:thumbsup::D:) to assuming nothing had been done.
+1
had a charade that was serviced by a reputable shop and the gearbox eventually died, the old fluid came out "like water" the mech told me so it was way past its service interval.
i do my gearbox and diff oil every 40k km, which is what the service manual states
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5364307
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
