did my diff oil today, not too much problem, bolts were fairly easy to take off..
Read somewhere that the diff takes about 1.9 - 2L.. I had the car on level ground with a hand pump siphon but could only manage to get about 1.5L. I tried pumping more in but it was dibbling out quicker than i could get it in.
Should it still be ok?
https://www.sau.com.au/forums/topic/328114-diff/
Yep it takes about 1.5 - as long as it continues to come out after you've pumped it in then you're sweet :D
Use an 80w90 for a mostly street-driven vehicle, and circa 85w140 for a track car. Does not need to be LSD fluid for a standard viscous GTS-T diff.
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5354352
what diff oil did you use? i was looking at doing mine soon.
used castrol SAF-XA rear axel diff oil 80w90, took about 1.5L
get a hand siphon off ebay its like 10 bucks, it saves soooooooooooooo much time.
birds - yep it was coming out quicker than i could pump it in so figured it was full
havent really found much difference doing the diff oil - it doesnt shudder as much if anything
Edited by defari
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5357807
You probably won't notice much, it's not much of a human interaction device like the gearbox where you can feel through your hand the difference between different oils and fresh/old. Also, diff and gearbox oil can last a long time as it is not exposed to much in the way of contamination like engine oil is. Were you just doing a service interval change or were you trying to fix a diff problem?
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5357906
just a service. Had no idea when it was last done / ever done by previous owners. Got all the oils cheap too.
The GB oil change though has made a difference, although the gb never crunched etc, i did it for the same reason as the diff (wasn't sure when it was last done) The gearbox was getting a bit "whiny" in the first 5mins of driving in the morning - the whining noise is somewhat gone but can still hear it slightly however i noticed the car wasnt as jerky when i was getting on/off the gas. Also the gears just felt more "solid".
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5358234
:thumbsup::D:) to assuming nothing had been done.
+1
had a charade that was serviced by a reputable shop and the gearbox eventually died, the old fluid came out "like water" the mech told me so it was way past its service interval.
i do my gearbox and diff oil every 40k km, which is what the service manual states
https://www.sau.com.au/forums/topic/328114-diff/#findComment-5364307
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
