Hey guyz, going to get an alarm soon in my r33 and was wondering if my car has an actuator so i can save a little cash if its there?
I opened the drivers side door and there is a unit with an aerial sticking out/ Does that mean it has one?
The car didnt come with any remotes but even under the dash there is a box that looks like a factory alarm box.
thanx 4 the help.
Cheers.
Vish.
Hey mate. Sounds like your car does/did have a factory alarm/central locking. But chances are that if you didn't get remotes with the car, you might run into trouble getting replacement ones, as most factory systems require one working remote to code a new one if that makes sense? Don't worry too much about the cost of the (i'm assuming) door actuators, as most remote alarm/immobiliser/central locking kits will come with actuators, and you car buy cheap basic central locking kits with 4 actuators for as little as $20-$30 with universal fit 4 wire actuators. Hope that helps. :whistling:
My car had a factory actuator, had to buy an after market one anyway as it would not work with the new alarm properly, missing some wires or something, cost an extra 50 bucks fitted, no biggie. So i wouldn't worry too much.
100% sure your car will have a factory actuator.
if the immobilizer/alarm system cannot use it and needs another one then its shit, get another one
im using a cyclops one, cost'd around $120 from memory (can look it up and find out for sure if ur interested) and it done everything, central locking, its got an alarm, boonet switch and shock sensor, and i also bought a chip which you change over which allows it to work with a turbo timer, this wasnt very expensive and was very easy to swap over (in and out)
i can do a cashy and install one if u want, or our workshop does pretty good price on supply & installs on immobilizers (autowatch) the very very basic ones, and also keypad ones.
in ur other thread u said u were on a bit of a budget, id recomend the cyclops, but if u want a mother of a systhem then go for an autowatch one they do an awsome kit with motion sensors and all that crap.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
