  Beelzebub89 said:
Not a bad start. I hope you're in one of the states that don't have any p plater restrictions otherwise you will have a tough time getting through your p plates.
WA plates - no restricitons... YET
mate nice 33 just please dont rap it around a pole or try and impress your friends on the street, they already have a bad enough rep.
also how did you find that for 5K ??? whats wrong with it?
  (OO)SKYLINE(OO) said:
Yeah, don't put the BOV on unless you are fitting the stock BOV back on, which you should already have.
ROFL +1
Congrats on the purchase though... looks pretty good for the price - anything wrong with it?
to answer the OP's questions of "What do ya think? Good car for an L plater", for 5 grand i wonder what's wrong with it, and no i don't think it's a good car for an L plater.
and as was said above, just leave the stock bov on there. don't rice ti up with an atmo bov. if you want to hear the stock bov more then put a higher flowing air filter on it.
  • Like 1
your car will have stalling issues if you put a atmo bov on a stock rb25det, don't waste your money and time, just do what mad said and get a high flow panel filter & fmic and you will here the stock plumb back one, and if your after a pod aswell, it is useless unless you fully enclose it, high flow filter is enough flow for now.
  • Like 1
  L-Plater said:
Its an r33 gts-t, picked up for 5 grand cash :)
Stock as a rock, but fitting a BOV and new gasket this weekend.
Probably in the wrong forum, but couldnt find a better one
What do ya think? Good car for an L plater(;
So.. Head gasket??.... "old mate was real honest, it was perfect apart from the headgasket going, and that was only because of the plastic bag that got stuck in the radiator, and nothing else is damaged at all, he was real sad to see it go, he really wanted to fix it, because it is a cheap fix, but his wife just had 10 kids and he has to buy a people mover...."
There is no such thing as a cheap Skyline... Let's pray that with this one clearly having major issues it will not be fast enough to get wrapped around a pole...
nice buy mate, but the wheels, exhaust and wing i noticed in pics arent from factory.
i dont think ive ever seen any skyline go for $5,000, well nothing that has a motor or driveline attached.
you bought privately i assume? i'd get it taken to a mechanic asap to get everything checked out, just to be sure.
oh.. and heed the advice on these forums is my advice :)
Edited by LANDSCRIBBLE
I got my 32 for $5k
It ran, but it sure needed some TLC... still needs some now TBH.
congrats to OP on the score. Heed everyone's advice and have her checked out though. Last thing you need is a faulty bilge pump!!
Aha, had a good laugh reading through all the comments(;
The 'gasket' is referring to replacing/repairing the rocker roller cover, which is leaking a few drips of oil. Had a qualified mechanic mate come out with me to have a look at it, just using his terms.
The only other problem would be the rear suspension bushings, which id consider fairly worn. Before I get my license i'll get them replaced.
Also done 172xxxkms, hence reasoning for the price. Besides that mechanically A1 :P
Just picked up a K&N pod filter (from someone on here), which is going in tomorrow.
Theres also a large fmic (from a vl turbo kit) going on in a few weeks. Mate said it should suit fine, anyone with experience care to enlighten?
Dont worry, you wont see this wrapped around a pole on 7 News anytime soon(;
Edited by L-Plater
Also done 172xxxkms, hence reasoning for the price. Besides that mechanically A1 :D
Gonna need a full hektik stereo and a much bigger wing before you can run with us real racers :P
    • It might be fine. I was just saying that I wouldn't trust it without testing it.
    • Traction wasn't bad, l couldn't give it everything off the line but was able to go WOT about half a second after rolling - good for NZ drag strips.   Like one run I did a 1.96 60ft and pretty sure I was on for a 12.4 but lifted early as I was on a 12.5 dial in, and still won haha
    • Nice one! I was going to take mine down to SMSP drags one Weds night. I'd love to compare it with my GTR which did a 12.3. The bum-dyno in the 335i says its quicker.   How was the traction @Lithium?
    • AFAIK I've seen other people recommend using the back of the balance tube as well. Andre Simon from HPA at least. I can't imagine it being that far off from ideal even if it was only used to drive a boost gauge from the factory.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
