  L-Plater said:
Little harsh up top there. All been in good faith mate.
I'm becoming a little skeptical of my mates mechanical ability. I have put my trust in someone that has completed their apprenticeship + TAFE to know what they're on about, but having realised that I can install the pod filter myself.. im a bit suss of him.
The forums have been great, and a good way to source advice, parts & knowledge :D
Anyway, not important. What I'm looking for is a way to unbolt the AFM, seeing as the bottom bolts are impossible to reach :D
Already got my clamps, pod cleaned/oiled up & adaptor all ready to go, just got to get the bloody thing off
If I'm bored this arvo I might take my shit apart and post back with results.
oookayy... I can't edit my post.
That golden ring is bending like a mother f**ker... really, only thing I can think of is unbolting it regardless of the damage to it, and picking up another one from somewhere.
Edited by SKITTLES
WHAT A f**k AROUND.
Just been outside for the last 2 hours w/the old man attempting to fit it.
Main areas of concern being the filter being ridiculously hard to fit to the adaptor, its on to a point where it's not going to fall off but if I clamped it i'd be clamping onto nothing
The pods got nothing to stand on, its just chilling resting on top of the pipe underneath.
And the presence of a gap between the adaptor gasket and the adaptor, along each long side. Im worried that this will suck air in, there's no way for me to tighten it.
The golden ring thing is still attached, not sure if it's meant to stay on or not.
Love anyone who knows what they're doing to help me out :P
ok... i think you didnt need to oil that filter. im pretty sure its a dry filter...
the filter. goes on to the adaptor... the adaptor bolts on to the afm... you have to make sure you have the right adaptor.
which means take your afm. go to autobarn or super cheap. get them to give you an adaptor to match.
even if the holes on the adaptor are too far apart. you can always drill new ones.
there should be a rubber o-ring on the face of the afm (if im correct) this should seal the air.
of the bottom bolts of the afm are hard to reach. take out the rubber pipe that the afm is connected to. the one that goes to the turbo... i know that seems like "wtf" but sometimes you hafta do it. just for unbolting the afm.
once you have the adaptor on the afm... bolt it on to the rubber intake pipe whilst its all out of the engine... then install the ruber intake pipe over the turbo...
and then lastly force in the pod filter.
as for the pod sitting on nothing. thats fine. if you want to brace it down.. connect 2 zipties together and ziptie it to the pipe underneath. (your going to use alot of zipties with this car, liek alot of ppl do) BUT its temporary... get a bracket made up. heck get some spare sheet metal n bend it up yourself... its easy just bolt it to the back of one of the bolts thats on the afm. and then to an existing hole on the car..
i hope i didnt confuse you.
post up some pics. if your unsure. pics always help
Thanks for the posts, been very helpful :nyaanyaa:
All i'm concerned about now is that the pod filter (it does need to be oiled, came with a cleaning&oiling kit) seems to have an incredibly tight fit with the adaptor, as in it seems too "tight" and too "shallow" to fit on properly.
Also the gap in the rubber gasket concerns me, surely that isnt meant to be there
Will pull it apart this arvo and let ya know :)
Thunderbirds are go. Got it all in&running, everything is sweet.
Cheers for all the help guys, really appreciate it. These forums are a great source of info :(
Loving the sound of the pod on boost ;)
  • 1 month later...
  R33 GTS TURBO said:
Hey dude i would double check the rules for having a turbo car as i just got off my red p's today and was not allowed to drive a turbo. Also live in Perth
Huh? :ermm:
From the WA DPI site, there is no mention of Car restriction for P platers in WA, only the time restriction for Red Ps & the no alcohol limit.
  Quote
Once you are grated a provisional license you will be on P plates for two years and the following rules and conditions apply:
  • You must display your P plates at all times when driving
  • You must have a zero blood alcohol level at all times when driving
  • Committing certain driving offenses as a P-plater could mean you automatically lose your license
  • You cannot drive between 12am-5am for the first 6 months after you have first become a P plater. For this period you will need to display red P plates. After the first six (6) months, you will be able to drive at any time of day and you will need to display green P plates. There are certain exemptions concerning these conditions. Please see the Rules for novice drivers (includes L and P platers) web page for more information.
I saw an L plater driving a Merc C63 AMG once...
Edited by Mayuri Krab
  • Like 1
I'm pretty sure in Victoria the restriction is only on P Platers, not L Platers.
So if your dad has a VE SS, you can learn to drive on it, but once you get your licence it's a big no no.
Makes sense if you ask me. I can't see many L Platers going spastic in a high powered car with mummy or daddy in the passenger seat. At least not if they had my parents lol.
  • Like 1
I got my R33 for $4500... 100,000km's on the clock. Mint condition with a kit :P I Guess I scored lucky. No paint or mechinical problems. Immaculate inside and out.
Must say, it's a good feeling to see someone with another stroke of luck
  • 5 months later...
  On 24/02/2011 at 11:24 AM, Vendalix said:
sooo...is turbocharged cars restricted in WA for provisional drivers? I searched the forum and haven't got a clear answer. Am really close in getting an r33 as a first car.
No, go to the WA dpi site & it will say what I stated b4.
No restrictions on any cars (you can drive a Lambo, AMG, M5 if you have rich parents...), the current restriction for P platers are: 0 alcohol limit, night driving ban (from midnight till 5am for red Ps) & the newly introduced low demerit point system (4 point for Ps & 8 for Greens).
WA is one of the few states in Australia that doesn't yet have a car restriction list for P-platers, all the Eastern staes have them.
EDIT: DPI site: http://www.transport.wa.gov.au/licensing/20626.asp
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
