Hi
I need to replace the rear passenger tie rod end. There is a noticable wobble in the wheel which was picked up by mechanic.
Im trying to get the part so he can replace it. Im having trouble finding out the part number or where to get them from. I've tried bursons and a local tyre place but they both cant find a listing. Bursons said they could have a look if i could remove the part ,but id rather not go down that route incase it takes a while to get on ordered in.
Im guessing the fronts are different to the rear, i alos have the lock bar fitted if that makes a difference. Im also thinking of getting some bushes replaced are there any thats more easily done while the tie rods getting replaced? or should i wait and get the lot done.
https://www.sau.com.au/forums/topic/328197-where-to-get-rear-tie-rod/
You can get them from nissan or try wreckers if your willing to use a second hand one, thats what I did and there fine. Or you can search around for after market ones but yeah like they told you if you take it off and show them itll be easier to match.
thats easy enough advice, but ive been searching for new outer tie rod ends for my R33 for some time, still no luck.
from Nissan NZ they said NZ$200 per side ($400 wtf?!?!?!) so I've been trying to find aftermarket, with no luck what so ever.
isnt really easy to just take them out and take them around the shops either given that half the hub assembly has to come apart to pop them out
if i do have to end up spending that ridiculous amount of $$$ to nissan for such parts, im thinking of looking at the driftworks eliminator kit which isnt much more.
If you guys are talking about the 'ball joint' that is pressed into the rear knuckle, they are not much fun to replace. I did both sides in my R33 a couple of weeks ago at work.
From memory retail from Highway Nissan, south brisbane was a bit under $100 each. Can't remember exactly as I didn't pay retail, certainly not $200ea.
If I was to quote somebody a figure for labour to fit both sides, I'd have to say 2 hours, $200. That's only because now I've done it I know how to do it without wasting time. The first time I did it, on my own car, it took nearly 2 hours to do the first side and about an hour for the other side.
If you're not talking about those joints, your mechanic is trying to rip you off, unless he's talking about the joint in the 'tie rod' which bolts to your hicas lock bar. If that's the case, I've never tried to buy those.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
