Hey guys,
Recently I just did a +t conversion on my RB25 and I used a stock BOV. It's working great, but I'm just having some issue (or maybe not??) with my BOV. Everytime I press the clutch down, my car's revs goes way down past the idling rev before jumping back up to the idling rev. To me, this seems more like something you would experience with an atmo BOV since the air is not in a closed-loop, but mine is plumbed back. Since I don't know how a "working" stock BOV is supposed to feel on a DEt, I just wanted to know if this was normal, or whether I have a vacuum leak or a stuffed BOV.
Any info would be much appreciated. Thanks guys!
https://www.sau.com.au/forums/topic/328237-stock-bov-question/
Is your return modified? If so it might be to big. Might be a leak or you need a tune. Im guessing you have changed your ECU and tuned it?
Yeh, I T-pieced into one of the vacuum line going from the plenum to the charcoal canister. Is that a problem? I did use the larger of the two lines, so you might be right, it might be too big.
I am running pfc and it already had a tune.
or some of the returned air is blowing backwards through your afm. is the return line pointed towards the turbo or a good distance from the afm?
Well that's the thing, I am hearing A LOT of air going out of the system (like an atmo BOV), and I'm assuming passing through the afm, even though it's plumbed back. But like I said, since I don't know what it's supposed to sound like, I simply just assumed that because I was using a pod, it was natural for it to sound like that.
Thanks for the info guys. I'll give these tips a go and hopefully it'll fix the problem.
Edited by mjscar
I would say that's your issue there. If you don't have vacuum leaks etc then I would say it's something to do with the idle setting of the tune. On some occasions my R33 GTST doesn't like to idle. I can be when it's restarted after being warm. Eg idling fine when you pull in to get fuel and then start it up to leave and it starts to carry on. Sometimes get the same when the lights are all on, windscreen wipers and AC too etc I'd be asking your tuner to see if he can fix it.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
