Which Colour Of These Rims On My White 33
This is the clearest explanation out of those: Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. Basically you turn the engine with the tensioner bolt loose, then use the allen key to hold it while you torque it up. And yes after that a good guide is being able to twist it 90o in one of the long free lengths of the belt
good choice....I have a set of those and use them all the time including on this job. Plus, no-one wants a damaged nipple
By drifter17a · Posted
Thanks all, went with nismo strengthened belt and all genuine nissan idler and tensioner Question on RB25DET Neo Timing Tensioner: I have a question about the RB25DET Neo timing tensioner. In one of the videos (minute 20 of https://www.youtube.com/watch?v=17y37BB9xnA and minute 27 of https://www.youtube.com/watch?v=Pb99s2E9xUg), the process suggests tightening the tensioner pulley installation bolt to the specified torque initially, and then loosening it slightly to allow the spring to set the correct tension. Is this the correct approach? The R33 workshop manual on page 74 states: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. The way this is written is confusing. Does this mean: Undo the nut, then reduce the tension by turning clockwise? Snug the nut so it stays in position without applying tension to the belt while removing the timing belt? The manual wording makes it sound like the nut will tighten automatically when you turn the tensioner clockwise , which is unclear to me. Timing Belt Tension Adjustment Process: After loosening the tensioner nut, you turn the engine two full rotations by hand, which should set the correct tension. Once the tension is set, you tighten the bolt to 43 N·m (4.4 kg·m). Before tightening, you need to insert the Allen key into the hexagonal hole to hold the pulley in place while tightening the bolt. In one of the videos, it’s mentioned that you should twist the belt side to side, or turn it slightly to check if the tension is correct. The belt should turn halfway, indicating the right tension. However, I know that twisting or turning the belt is not a good idea. What are your thoughts on this? Finally, how can I ensure the belt isn’t overtightened? I’ve seen many cases where people have overtightened the timing belt. Manual Excerpts: Page 74: Loosen the tension pulley installation nuts. Insert the wrench into the tensioner pulley hexagonal hole and turn it clockwise to tighten the installation nut temporarily. Remove the timing belt from each pulley. Page 77: Turn the crankshaft clockwise two full rotations with the tensioner pulley installation bolt in a loose condition. Insert a wrench into the tensioner pulley hexagonal hole to fix the tensioner pulley in place, then tighten the installation bolts. Tightening torque: 43–58 N·m (4.4–5.9 kg·m). The timing belt tension should be at the correct tension. -
Takes a few minutes to malke one. Wood, or steel, or a wrap strap with some strategically placed solids to provide teh drive onto the ribs.
I would strongly suggest using the correct tool. They are not expensive and make the job much easier and don't damage the lock ring. Google "fuel tank lock ring removal tool" to see what I'm talking about.
