Hey guys,
I was cleaning my headlights this morning and stupidly used a duct tape to mask up the surrounding bumpers.
When i peeled the tape off i unfortunately peeled a strip of paint off the front bumper
When i picked the car up it already had a slight scrape on the other side of the bumper which im thinking i may just get both problems fixed at a panel beater.
Couple of questions - how much should i expect to pay to get a panel beater to fix the paint problems (pics attached)
could i do it myself instead fairly easily? I read in another thread Nissan do touch up paint for $12 or so dollars that comes with a brush?
Anyone recommend someone NOR?
Cheers for the advice.
Steve
Edited by s13-steve
would touch up paint work to cover it up completely? the paint is completely stipped in the first pic (the masking tape just pulled it right off)
also anyone know where to get KR4 touch up paint in Perth? I did a search and apparently Nissan is the best place to go?
Give Colortech a call http://www.colortech.net.au/.. he comes to you and has a computer/paint machine to colour match the exact paint code.
forgot the dudes name though.. 0413 133 902
Used him to fix up a trolley ding on my evo before and it came out perfect :blink:
Edited by aiball
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
