Lets say the limiting factor for your engine producing more power is the turbo, and not the fuelling system/strength of internals.
An example is the stock turbo on say an rb25det, being as to run say 12psi the turbo has to spin harder and harder as the revs rise to continue to keep producing the same boost level (as more air is required) it is obvious it is going to be spinning almost twice as fast at say 7500rpm opposed to 3500rpm even though the boost level remains the same.
Now I was wondering if this means you could run say 15-18psi at low rpms when the turbo first comes on, say around 3-4500rpm and then have it drop back down to 10psi towards redline. This way you would be maintaining fairly constant rpms in the turbo and you would be getting far more power in the midrange without overspeeding it at redline.
Now this is assuming that reason the air heats up in the turbo is due to the speed it is operating at, and not the pressure it is running. Could someone confirm if my thinking is correct or not? Because if it is and the air temps are ok at low rpm even at higher boost levels, then I cannot think of any reason why this would be detrimental to the engine or the turbo, providing of course the motor/fuel system could sustain 18psi.
think youll find that running higher boost will be a problem rather then the rpm
I dont think the RPM of the turbo vs the RPM of the engine is as relative as twice the engine rpm is equal to twice the turbo rpm exactly. Boost creates heat through friction im pretty sure, there will be heat from high rpm as well but yeah im not sure your plan will work, though it is a good idea
I'm not sure it will work either otherwise other people would have done it by now, but I'm curious as to where I am going wrong. I suspect that intake heat is a function of boost pressure, not how much air it is supplying as if this is the case, then what I proposed doesn't work.
when my ebc was still working, my car was tuned at 15psi on the stock turbo up to about 4krpm, and then down to 12 psi till redline.
i asked the tuner about it, and he said at the lower rpm the turbo can handle it fine, as long as it's not still running 15psi at the top.
i was a bit suss, but he was confident.
his reasons were the same as yours. to give it a nice kick coming onto the power. makes it feel much quicker.
it was absolutely fine till the ebc stopped working. now i'm just running 13ish psi with a MBC.
Edited by Munkyb0y
Evos do this from the factory, and if you look at a compressor map, you can see why. The factory boost control runs directly along one of the efficiency line.
In factory spec they spike to what, 20psi and drop back to around 1bar
However - interestingly - you can actually hold 18-20psi right until redline once you give some boost control & a tune on the factory turbo.
Suddenly you've then gone from 140-150awkw (EVO9) to a tad over 200 on the factory turbo without a drama in the world. Clearly arguing the point about efficiency.
It could just being setup like that most likely to conserve motor/parts and so on.
I'm a bit dubious of such a compressor map for the EVO turbos based upon this (the above im talking EVO 7/8/9)
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
